Set Zoom To Full Extent On Exsisting Graphics On Map Instead of Base Map
9179
17
01-13-2017 02:54 PM
BehrouzHosseini
Using ArcGIS JavaScript API 3.19, I am simply adding some Point Graphics From a JSON object (Schools)  like below
var data = [{
 "SCHOOL_NAME": "King George Sec.",
 "LATITUDE": 49.2898,
 "LONGITUDE": -123.1364,
 "ADDRESS": "1755 Barclay St",
 "URLLINK": "http://www.vsb.bc.ca/schools/king-george"
 "SCHOOL_NAME": "Britannia Sec.",
 "LATITUDE": 49.2752,
 "LONGITUDE": -123.0719,
 "ADDRESS": "1001 Cotton Drive",
 "URLLINK": "http://www.vsb.bc.ca/schools/britannia-secondary"
 "SCHOOL_NAME": "Magee Sec.",
 "LATITUDE": 49.2286,
 "LONGITUDE": -123.1515,
 "ADDRESS": "6360 Maple St",
 "URLLINK": "http://www.vsb.bc.ca/schools/magee"
to the map. now I would like to add a functionality to Zoom to Full Extent of ONLY school points on the Map. Technically I add the `Navigation` class to the Map
require(["esri/toolbars/navigation"], function(Navigation) { /* code goes here */ });
and in HTML I have a simple button
<button id="show-all-schools">Show All Schools</button>
and in JS I have
$("#show-all-schools").on("click", function () {
            navToolbar = new Navigation(map);
            navToolbar.zoomToFullExtent();
but this is setting the basemap in Full Extent state! Can you please let me know how to pass a parameter like points to zoom to cover entire points instead of basemap?
Thanks
Tags (1)
RobertScheitlin__GISP
Bengi,
   It would be:
map.addLayer(schoolGraphicLayer);
 $(".zoom-to-point").on('click', function(){
  var schoolGraphicsExtent = graphicsUtils.graphicsExtent(schoolGraphicLayer.graphics);
  map.setExtent(schoolGraphicsExtent, true);
Behrouz,
   The Navigation widgets zoomToFullExtent is always going to zoom to the basemaps full extent:
Zoom to initial extent of base layer
Instead of using the Navigation toolbar you should just set the maps extent to the school layers extent.
Map | API Reference | ArcGIS API for JavaScript 3.19 | setExtent
BehrouzHosseini
Thanks again Robert
I tried this way as the `schoolGraphicLayer` is my graphic layer added to the Map already
            map.setExtent(schoolGraphicLayer);
but nothing is happening! Can you please let me know what I am doing wrong?
Behrouz,
  So what you are doing is trying to the map extent to a featurelayer then.
This is more like it:
map.setExtent(schoolGraphicLayer.fullExtent, true);
BruceGreen
Thanks Robert,
I Update the code to
But I am getting this error now!
BehrouzHosseini
Hi Robert did you have a chance to take a look at this issue? Thanks
Did you check the value of the fullExtent property? The main reason for that error is that property is null.
BehrouzHosseini
Thanks for reply Robert but how can I check this? if this is about
schoolGraphicLayer
I am sure that I have many graphics there already!
add a line like this
console.info(schoolGraphicLayer.fullExtent);
BehrouzHosseini
You are right console.log() is returning undefined
can you please let me know why and how I can fix this? should I set an initial custom extent?
