Select multiple layers and export
2204
12-23-2022 01:55 AM
Vakhtang_Zubiashvili
Hi Guys,
On my map i want to select multiple layers by drawing rectangle and than export selected features fields. i have this code thanks to @BlakeTerhune   (From my previous topic😞
// create a new sketch view model set its layer
        const sketchViewModell = new SketchViewModel({
          view: view,
          layer: polygonGraphicsLayerr
        // Once user is done drawing a rectangle on the map
        // use the rectangle to select features on the map and table
        sketchViewModell.on("create", async (event) => {
          if (event.state === "complete") {
            // this polygon will be used to query features that intersect it
            const geometriess = polygonGraphicsLayerr.graphics.map(function(graphic){
              return graphic.geometry
            const queryGeometry = await geometryEngineAsync.union(geometriess.toArray());
            selectFeatures(queryGeometry);
        // This function is called when user completes drawing a rectangle
        // on the map. Use the rectangle to select features in the layer and table
        function selectFeatures(geometry) {
            // create a query and set its geometry parameter to the
            // rectangle that was drawn on the view
            var query = {
              geometry: geometry,
              outFields: ["*"]
            map.allLayers.forEach(layer => {
            // Query all layers data
                layer.queryFeatures(query)
                .then((results) => {
                    // do something with query results
                  console.log(results)
                .catch(errorCallback);
When i draw rectangle in logs i get error:  layer.queryFeatures is not a function;
what i do wrong? What is wrong here and i can not see? Help
JoelBennett
MVP Regular Contributor
Your code is assuming that all layers in your map are FeatureLayers, but that is unlikely.  You should therefore check the layer type before trying to execute a query on it.  One simple check would be like so:
	if (typeof layer.queryFeatures == "function") {
		layer.queryFeatures(query).then((results) => {
		}).catch(errorCallback);
JoelBennett
LefterisKoumis
JoelBennett is correct.
			if (layer.type === "feature" && layer.visible){
Thank You guys @JoelBennett @LefterisKoumis , both code works fine, simply checking layer type 😉 Thanks again for help.
