Search: "Pagination is not supported."
11357
11
03-26-2015 03:13 PM
BenFousek
Trying to get the new Search running against a feature layer. enableSuggestions and enableSuggestionsMenu are false. Don't see anything else in docs which warns of 10.3/supportsPagination = true.
Any help appreciated.
sources: [{
  featureLayer: new FeatureLayer('.../Parcels/FeatureServer/0', {
  outFields: ['*']
  searchFields: ['ADDRESS', 'PARCEL_ID', 'OWNER'],
  displayField: 'ADDRESS',
  exactMatch: false,
  outFields: ['*'],
  placeholder: 'Search parcels',
  enableSuggestions: false,
  enableSuggestionsMenu: false,
  minCharacters: 3
Tags (1)
NikhilSharma
Hi Guys,
Just to inform all that I got rid of this error for a feature layer from a map service(mapserver/0) simply by checking if pagination is supported or not for all the sources inside a for loop. Here is the code snippet:
  search.on("load", function () {
  var sources = search.sources;
  sources.push({
              featureLayer: layer,
              enableLabel: false,
              searchFields: ["STATE_NAME"],
              displayField: "STATE_NAME",
              exactMatch: false,
              outFields: ["*"],
              infoTemplate: new InfoTemplate("Ecological Footprint", "<a href= ${URL} target=_blank ;'>Additional Info</a></br></br>OBJECTID : ${OBJECTID }</br>")
  for(i=0;i<sources.length;i++)
var supported;
if (sources.featureLayer) {
                // supports pagination
                if (sources.featureLayer.advancedQueryCapabilities && sources.featureLayer.advancedQueryCapabilities.supportsPagination) {
                    supported = true;
  if (!supported) {
                        sources.maxResults = "food";
            search.set("sources", sources);
        search.startup();
I am attaching a working sample application along with this as well.
Hope that helps.....
Regards,
Nikhil. !
NikhilSharma
Hi Guys,
  sources.push({
              enableLabel: false,
              exactMatch: false,
              outFields: ["*"],
var supported;
                    supported = true;
  if (!supported) {
        search.startup();
Regards,
Nikhil. !
