Route paramter is not effecting in Direction widget
1298
09-09-2016 09:20 AM
Haider_AliFaheem
I trying to create a demo with Direction widget and Javascript api 3.17.when i try to modify any routing parameter it did not effect.i am trying to get the route by setting the route parameter  returnRoutes=true but direction request the solve with returnRoutes=false.i also tested with startTime parameter but its also not working.
could you please help me in this regards
my code snippet is following
 var s_params = new RouteParameters();
s_params.returnRoutes = true;
this.directions = new Directions({
map: me.map,
routeTaskUrl: url,
routeSymbol: sym,
directionsLengthUnits: 'esriKilometers',
routeParams:s_params,
canModifyStops: false,
showMilesKilometersOption: false,
showReturnToStartOption: false,
showTravelModesOption: false,
showPrintPage: false,
returnRoutes:true
}, 'directions');
this.directions.startup();
this.directions.on('directions-finish', lang.hitch(me, me._directionsFinished));
i also try to pass the parameter as Json.also try to Update the Routetask property.but still the same issue
Could you please help me in this regards
