Right click to pan map mid draw (hybrid mode)
1386
01-16-2025 04:42 AM
PaulStanway1
Scenario: User is drawing a polygon using hybrid mode, has kept left click down to draw freehand then releases the left click, ready for next vertex click but wants to pan the map before doing so.
At this point mid draw, the user needs to be able to right click, keep right button down, and move mouse around (drag) to pan the map then continue to freehand draw or point click, is this possible?
Example hybrid mode drawing here > https://codepen.io/Paul-Stanway/pen/xbKpExL
Can someone provide updates to the above codepen to achieve this pan mid draw using right click hold.
I found an example using non hybrid vertex drawing below link, using left click hold to pan but left click cannot be achieved with hybrid as left click hold draws multiple vertex as mouse is moved so need to use right click hold somehow. > https://codepen.io/U_B_U/pen/oNVGzqX?editors=1000
Sage_Wall
Hi @PaulStanway1 , is there a reason the arrow keys on the keyboard cannot be used for panning the map mid-drawing?  Does it need to be a right click?
PaulStanway1
Hi, thanks for the reply, yes the mouse and right click need to be used not the keyboard arrow keys
Sage_Wall
Sorry @PaulStanway1 I'm not really sure how to do this either at least without tying to figure it out myself. Hopefully someone else more familiar with the sketch view model can help.
ReneRubalcava
Esri Frequent Contributor
This isn't perfect, but does mostly work.
https://codepen.io/odoe/pen/jENpyGy?editors=0010
  let handle;
  view.on("pointer-down", (e) => {
    // right-click
    if (e.native.which === 3) {
      // drag
      handle = view.on(
        "pointer-move",
        debounce((event) => {
          const mp = view.toMap(event);
          view.goTo(mp);
          // mouse up from drag
          let handle2 = view.on("pointer-up", () => {
            handle.remove();
            handle2.remove();
