Reverse geocode not working,
3525
10-10-2015 06:41 AM
lasinh
hi all, i use geocoding services, clickmap get address but my code is not working? but in the example given by esri that it working
Reverse geocode | ArcGIS API for JavaScript
mycode:
<!DOCTYPE html>
<html>
  <head>
    <meta http-equiv="Content-Type" content="text/html; charset=utf-8">
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
    <title>Find Address</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.14/esri/css/esri.css">
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      #map {
        padding: 0;
        border: solid 2px #666;
        margin: 0 5px 5px 5px;
      #header {
        color: #666;
        font-family: sans-serif;
        font-size: 1.1em;
        height: auto;
        margin: 5px;
        overflow: hidden;
        padding: 10px 0 10px 20px;
        text-align:left;
      .roundedCorners {
        -webkit-border-radius: 5px;
        -moz-border-radius: 5px;
        border-radius: 5px;
    </style>
    <script src="http://js.arcgis.com/3.14/"></script>
    <script>
        var map;
        require([
        "esri/map", "esri/tasks/locator", "esri/graphic",
        "esri/geometry/webMercatorUtils",
        "esri/symbols/SimpleMarkerSymbol", "esri/symbols/SimpleLineSymbol",
        "esri/InfoTemplate", "esri/Color",
        "dojo/number", "dojo/parser", "dojo/dom", "dijit/registry",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function (
        Map, Locator, Graphic,
        webMercatorUtils,
        SimpleMarkerSymbol, SimpleLineSymbol,
        InfoTemplate, Color,
        number, parser, dom, registry
          parser.parse();
          map = new Map("map", {
              zoom: 0
          var tiled = new esri.layers.ArcGISTiledMapServiceLayer("url");
         map.addLayer(tiled);
          var locator = new Locator("url");
          locator.outSpatialReference = map.spatialReference;
          //          var infoTemplate = new InfoTemplate("Location", "Address: ${Address}");
          var symbol = new SimpleMarkerSymbol(
          SimpleMarkerSymbol.STYLE_CIRCLE,
          15,
          new SimpleLineSymbol(
            SimpleLineSymbol.STYLE_SOLID,
            new Color([0, 0, 255, 0.5]),
            8
          new Color([0, 0, 255])
          locator.on("location-to-address-complete", function (evt) {
              var abc = "123";
              if (evt.address.address) {
                  var address = evt.address.address;
                  var location = webMercatorUtils.geographicToWebMercator(evt.address.location);
                  //this service returns geocoding results in geographic - convert to web mercator to display on map
                  // var location = webMercatorUtils.geographicToWebMercator(evt.location);
                  var graphic = new Graphic(location, symbol, address, infoTemplate);
                  map.graphics.add(graphic);
                  map.infoWindow.setTitle(graphic.getTitle());
                  map.infoWindow.setContent(graphic.getContent());
                  //display the info window with the address information
                  var screenPnt = map.toScreen(location);
                  map.infoWindow.resize(200, 100);
                  map.infoWindow.show(screenPnt, map.getInfoWindowAnchor(screenPnt));
          map.on("click", function (evt) {
              map.graphics.clear();
              //              try {
              locator.locationToAddress(webMercatorUtils.webMercatorToGeographic(evt.mapPoint), 1000);
              //              catch (ex) {
              //                  var address1 = evt.address.address;
              //                  alert(address1);
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer"
         data-dojo-props="design:'headline', gutters:false"
         style="width:100%; height:100%;">
      <div id="header" class="roundedCorners"
           data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'top'">
        <span>Click the map to get the address for the input location.</span>
      </div>
      <div id="map" class="roundedCorners"
           data-dojo-props="region:'center'">
      </div>
    </div>
  </body>
</html>
RobertScheitlin__GISP
Ia sinh,
  The issue you were having is that your GeocodeService is in a different projection that WGS 84 that you where attempting to convert the click geometry to. I also remove the Legacy coding that you were using for ArcGISTiledMapServiceLayer and preformed some other code cleanup.
<!DOCTYPE html>
<html>
<head>
      on iOS devices-->
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    #map {
      padding: 0;
    #header {
      color: #666;
      font-size: 1.1em;
      height: auto;
      margin: 5px;
      overflow: hidden;
      text-align: left;
    .roundedCorners {
      border-radius: 5px;
  </style>
  <script>
    var map;
    require([
        "esri/geometry/webMercatorUtils", "esri/layers/ArcGISTiledMapServiceLayer",
      ], function (
      webMercatorUtils, ArcGISTiledMapServiceLayer,
      parser.parse();
        zoom: 0
      var tiled = new ArcGISTiledMapServiceLayer("http://115.79.20.1:6080/arcgis/rest/services/Atlas2015/NEN_KTXH_150715/MapServer");
      var locator = new Locator("http://115.79.20.1:6080/arcgis/rest/services/Geocode/GEOCODING_SONHA_BH/GeocodeServer");
        15,
          8
          var infoTemplate = new InfoTemplate("Location", "${*}");
          var graphic = new Graphic(evt.address.location, symbol, address, infoTemplate);
          map.infoWindow.show(evt.address.location);
        locator.locationToAddress(evt.mapPoint, 1000);
  </script>
</head>
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="width:100%; height:100%;">
    <div id="header" class="roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'">
    </div>
    <div id="map" class="roundedCorners" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
    </div>
  </div>
</body>
</html>
lasinh
Thanks Robert, It is working,
But if i change the coordinate system my code obove is working or is not
And i used geododeService above in directions widgets, but My code did not work as I expected, when i clickMap to add a point to input parameter of directions widgets also adds at coordinates instead of address. How to adds Address to input directions widgets? thanKYou
My Code:
<!DOCTYPE html>
<html>
  <head>
    <title>Directions Widget</title>
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      body {
        background-color:#FFF;
        overflow:hidden;
        font-family:"Trebuchet MS";
    </style>
    <script>
        require([
       "esri/map", "esri/tasks/locator", "esri/dijit/Directions", "esri/dijit/Search", "esri/layers/FeatureLayer",
        "dojo/parser",
      ], function (
         Map, Locator, Directions, Search, FeatureLayer,
        parser
          parser.parse();
          //all requests to route.arcgis.com will proxy to the proxyUrl defined in this object.
              zoom: 0
          var tiled = new esri.layers.ArcGISTiledMapServiceLayer("http://115.79.20.1:6080/arcgis/rest/services/Atlas2015/NEN_KTXH_150715/MapServer");
          var directions = new Directions({
              map: map,
              mapClickActive: true,
              routeTaskUrl: "http://115.79.20.1:6080/arcgis/rest/services/NetworkRouter/network01102015/NAServer/Route",
              geometryTaskUrl: "http://115.79.20.1:6080/arcgis/rest/services/Utilities/Geometry/GeometryServer",
             // travelModesServiceUrl: "http://utility.arcgis.com/usrsvcs/servers/cdc3efd03ddd4721b99adce219629489/rest/services/World/Utili...",
              searchOptions: {
                  sources: [
                  locator: new Locator("http://115.79.20.1:6080/arcgis/rest/services/Geocode/GEOCODING_SONHA_BH/GeocodeServer"),
                  singleLineFieldName: "SingleLine",
                  name: "Custom Geocoding Service",
                  placeholder: "Search Geocoder",
                  maxResults: 3,
                  maxSuggestions: 20,
                  enableSuggestions: true,
                  minCharacters: 0
          }, "dir");
          directions.startup();
    </script>
  </head>
    <div data-dojo-type="dijit/layout/BorderContainer"
         style="width:100%;height:100%;">
      <div data-dojo-type="dijit/layout/ContentPane"
           data-dojo-props="region:'right'"
           style="width:250px;">
        <div id="dir"></div>
      </div>
      <div id="map"
      </div>
    </div>
  </body>
</html>
