Return a pop up window with who edit last
2376
07-11-2014 04:44 PM
AlexGole
Hi all,
I am building this web application that  enables the users to edit data. I have enable tracking edits/archiving to it. Now I am looking to have a window that says something like this "this layer was last updated 2 days ago by mike". I am not sure how to do this. I can Query but will that be enough? I am thinking of using this:
getEditSummary(feature, options?)StringReturns a localized summary of the last edit operation performed on the given feature, if available.
I am not too sure how to implement it in my code.
Can someone help?
below I am using the sample from ESRI to check if it works.
Thank you,
Alex
map = new Map("map", {
          basemap: "satellite",
          center: [-121.469, 38.556],
            zoom: 8,
          slider: false
        map.on("layers-add-result", initEditor);
        var rivers = new FeatureLayer("http://webgisdevint1/arcgis/rest/services/Alex_Try/AllOptions/FeatureServer/0",{
          mode: FeatureLayer.MODE_ONDEMAND,
          outFields: ['*']
        map.addLayers([rivers]);
        function initEditor(evt) {
          var templateLayers = arrayUtils.map(evt.layers, function(result){
            return result.layer;
          var templatePicker = new TemplatePicker({
            featureLayers: templateLayers,
            grouping: true,
            rows: "auto",
            columns: 3
          }, "templateDiv");
          templatePicker.startup();
          var layers = arrayUtils.map(evt.layers, function(result) {
            return { featureLayer: result.layer };
          var settings = {
            map: map,
            templatePicker: templatePicker,
            layerInfos: layers,
            toolbarVisible: true,
            createOptions: {
              polylineDrawTools:[ Editor.CREATE_TOOL_FREEHAND_POLYLINE ],
              polygonDrawTools: [ Editor.CREATE_TOOL_FREEHAND_POLYGON,
                Editor.CREATE_TOOL_CIRCLE,
                Editor.CREATE_TOOL_TRIANGLE,
                Editor.CREATE_TOOL_RECTANGLE
            toolbarOptions: {
              reshapeVisible: true
          var params = {settings: settings};
          var myEditor = new Editor(params,'editorDiv');
          //define snapping options
          var symbol = new SimpleMarkerSymbol(
            SimpleMarkerSymbol.STYLE_CROSS,
            15,
            new SimpleLineSymbol(
              SimpleLineSymbol.STYLE_SOLID,
              new Color([255, 0, 0, 0.5]),
              5
            null
          map.enableSnapping({
            snapPointSymbol: symbol,
            tolerance: 20,
            snapKey: keys.ALT
          myEditor.startup();
