This was working fine for us @ 9.3.1; however, upon upgrading to AGS 10 it will not print if we use our aerials layer. I am getting a 500 internal server error when the aerials are printed. All other layers (basemap, etc) print fine.Here is the error output (via Firebug):
[NullReferenceException]: Object reference not set to an instance of an object.
at MergeAndOutput.BlendNoSave(Graphics baseGraphics, Bitmap topimg, Double transparency) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 303
at MergeAndOutput.Blend(Bitmap baseimg, Bitmap topimg, Double transparency, String output, Int32 width, Int32 height) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 250
at MergeAndOutput.Blend(Dictionary`2 dict) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 208
at MergeAndOutput.ProcessRequest(HttpContext context) in d:\Inetpub\mPrint\printing\dotnet\MergeAndOutput.ashx:line 28
at System.Web.HttpApplication.CallHandlerExecutionStep.System.Web.HttpApplication.IExecutionStep.Execute()
at System.Web.HttpApplication.ExecuteStep(IExecutionStep step, Boolean& completedSynchronously)
Any ideas?
