Override LayerList layer name in 3.16
10361
13
05-19-2016 11:24 AM
SteveCole
Honored Contributor
So, awhile back, I posted this thread about changing the label associated with a layer checkbox in the LayerList widget. The solution posted in that thread (setting id: "some layer name") does not seem to work using the 3.16 API version of the layerList widget.
code snippet:
        // Initialize and set up the LayerList
        layerWidget = new LayerList({
           map: app.map,
           showLegend: true,
           showOpacitySlider: true,
           showSubLayers: false,
           layers: [
                {layer:wsdotBridgeLayer,
                visibility:true,
                {layer: KingCoBridgeLayer,
                visibility:true,
                id:"King County Bridges"
                {layer:priorityRoadsLayer,
                visibility:true,
           ]},"layerList");
        layerWidget.startup();
Result at load:
Has anybody encountered this and found a solution?
Steve
RobertScheitlin__GISP
Mehretab,
  Actually it does have a title property it is just not documented.
DavidColey
MVP Frequent Contributor
The LayerList also honors the title option in the layers array, I find that helpful for individual feature layers:
var layerList = new LayerList({
    map: mapMain,
    showLegend: true,
    layers: [{
    layer: lyrSide,
                title: "Sidewalks",
    layer: lyrBike,
                title: "Bicycle Lanes",
    layer: lyrTrans,
                title:"Transit Lines"
    layer: lyrShlt,
                title:"Sheltered Stops"
    layer: lyrStops,
                title:"Transit Stops"
    //layerInfo
    }, "layerListDiv");
SteveCole
Honored Contributor
David Coley​ THANK YOU! That's the golden ticket. Why hasn't this made it into the documentation?....
DavidColey
sure glad to help, I haven't been able to contribute in awhile.  Sometimes its just the small things
