LabelLayer name inside LayerList widget
4945
11-12-2015 11:51 AM
SteveCole
Honored Contributor
I'm using the LayerList for a small project. It basically meets my needs despite its limited functionality. Anyways, I added a labelLayer to my project to label the features of another feature layer in the project and I wanted to have the ability to turn the labels on/off. I added the labelLayer as one of the layers to the LayerList widget but I cannot figure out where it's getting the label text for the checkbox in the LayerList.
My simple code for the labelLayer:
        var renderer = new SimpleRenderer(symbol);
        var labelLayer = new LabelLayer("label1", {
            mode: "dynamic",
            visible:true
        labelLayer.addFeatureLayer(fsMpLayer, renderer, "M.P. {milepost}", { pointPriorities: "AboveRight" });
        labelLayer.setAlgorithmType("DYNAMIC");
        labelLayer.setMinScale(24000);
and for the LayerList...
        layerWidget = new LayerList({
           map: app.map,
           subLayers: false,
           layers: [
                // {layer: ortho2013Layer,
                // visibility: false
                {layer: geolMapLayer,
                subLayers: false,
                visbility: false
                {layer:memoSegmentLayer,
                visibility:false
                {layer: soilsLayer,
                visibility:false
                {layer: streamLayer,
                visibility:false
                {layer:roadsLayer,
                visbility:true
                {layer:mlhLayer,
                visibility:true
                {layer:fsMpLayer,
                visibility:true
                {layer:streamCrossingLayer,
                visibility:true
                {layer:maintConcernLayer,
                visibility:true
                {layer:labelLayer,
                visibility:true
           ]},"layerList");
        layerWidget.startup();
And inside the app, it just states "labels" as the text for the labelLayer checkbox:
Is there anyway to change that??
Steve
RobertScheitlin__GISP
Steve,
   Have you tried to set the id for the layer object:
{layer:labelLayer,
  visibility:true,
SteveCole
Honored Contributor
This is an extremely hack-ish way to do it but this will work:
        window.onload = function() {
            document.getElementById('layerList_checkbox_9').labels[0].innerText = "Milepost Labels";
First, you need to examine the HTML to find the ID of the checkbox in the layerList widget. Once you know that, you can modify it but it has to be done AFTER the page loads and all scripts run. That's why I have it in a window.onload event.
Reference 1
Reference 2
Steve,
{layer:labelLayer,
  visibility:true,
SteveCole
Honored Contributor
Well I'll be damned. That works too. Ugh. ESRI will never have enough (clear) documentation.
Thanks, Robert!
