Need help
1485
02-08-2020 08:14 AM
DawenXie1
Can someone here help me connect with a staff in ESRI's ArcGIS API for Javascript team? My email is: xie at virginia.edu. Thanks in advanced!#
Egge-Jan_Pollé
Hi Dawen Xie‌,
Welcome to GeoNet. The community is there to help.
What exactly is your question? I have seen members of ESRI's ArcGIS API for Javascript team around on this forum, so the the best thing you could do is post your issue here. In this way they will be able to help. And maybe other community members can also shed their light on your question.
HTH,
Egge-Jan
DawenXie1
Thanks Egge-Jan. We have been working on a visualization tool for Novel Coronaviurs (2019-nCoV) Surveillance Data
using an older version of ESRI API for Javascript (2019-nCoV Surveillance Dashboard). It's currently on beta release and we would like to share this with ESRI staff (and community) and potentially get some technical support from ESRI.
BenElan
Esri Alum
Hello,
If you want to open a case with Esri Technical Support, you can do so here:
Esri Support Contact Support
