Multiple pictureMarkers at the same location - how to view
1278
08-27-2013 09:56 PM
PetreCojocea
I have to put the map multiple  PictureMarkerSymbol at the same [lat ,long].
When I click symbol I need to see there are more than one marker there, currently are overlapping.
Ideally would look like google earth  where they spread around.
Is this possible or do I have alternatives?
Regards, Peter
ZachLiu1
Point geometry has a offset(dx, dy) method to offsets the point in an x and y direction. Units are map units. So you can give different points different offsets to mark them around the center location.
It depends on how many markers you have for the same location.
PetreCojocea
Thanks for the  suggestion, looking around I also found cluster marker as a possibility,
Looks to me these are the only 2 options  unless someone else  comes with a miracle solution.
