Migrated my project from esri-load module to arcgiscore (4.24.7), and managing assets locally(managing-assets-locally ) in ReactJS. Measurement , Sketch and SketchViewMode widgets which are working fine in esri-load module , after migrating to arcgiscore graphics not showing up while drawing through these widgets and getting this below error while map is loading.
Below screenshot while drawing through measurement widget
import React, { useEffect } from "react";
import Measurement1 from "@arcgis/core/widgets/Measurement";
import Expand from "@arcgis/core/widgets/Expand";
const Measurement = (props: any) => {
useEffect(() => {
const esrimeasurementWindow = document.getElementById("measurementDiv") as HTMLElement;
const esriexpandMeasurement = new Expand({
expandIconClass: "esri-icon-measure",
view: props.impMap,
content: esrimeasurementWindow,
props.impMap.ui.add(esriexpandMeasurement, "top-right");
const measurement = new Measurement1();
props.impMap.ui.add(measurement, "bottom-right");
measurement.view = props.impMap;
const distanceButton = document.getElementById("distance") as HTMLElement;
distanceButton.addEventListener("click", () => {
distanceMeasurement();
const areaButton = document.getElementById("area") as HTMLElement;
areaButton.addEventListener("click", () => {
areaMeasurement();
const clearButton = document.getElementById("clear") as HTMLElement;
clearButton.addEventListener("click", () => {
clearMeasurements();
function distanceMeasurement() {
const type = props.impMap.type;
measurement.activeTool =
type.toUpperCase() === "2D" ? "distance" : "direct-line";
distanceButton.classList.add("active");
areaButton.classList.remove("active");
function areaMeasurement() {
measurement.activeTool = "area";
distanceButton.classList.remove("active");
areaButton.classList.add("active");
function clearMeasurements() {
measurement.clear();
return (
<React.Fragment>
<div id="measurementDiv" className="esri-component esri-widget">
<button
id="distance"
className="esri-widget--button esri-interactive esri-icon-measure-line"
title="Distance Measurement Tool"
></button>
<button
id="area"
className="esri-widget--button esri-interactive esri-icon-measure-area"
title="Area Measurement Tool"
></button>
<button
id="clear"
className="esri-widget--button esri-interactive esri-icon-trash"
title="Clear Measurements"
></button>
</div>
</React.Fragment>
export default Measurement;
import { useEffect } from "react";
import GraphicsLayer from "@arcgis/core/layers/GraphicsLayer";
import Sketch from "@arcgis/core/widgets/Sketch";
const SketchSample = (props: any) => {
useEffect(() => {
const sketchgraphicsLayer = new GraphicsLayer({ title: "sketchgraphicsLayer" });
props.impMap.map.add(sketchgraphicsLayer);
const sketchModel = new Sketch({
view: props.impMap,
layer: sketchgraphicsLayer
const expandTopo = new Expand({
expandIconClass: "esri-icon-authorize",
view: props.impMap,
content: sketchModel,
collapseTooltip : "SketchSample",
expandTooltip : "SketchSample"
props.impMap.ui.add(expandTopo, "top-right");
sketchModel.on("create", (event: any) => {
if (event.state === "complete") {
alert("Draw completed in SketchModel !!");
return (null)
export default SketchSample;
//import { loadModules } from "esri-loader";
import "./SketchViewModelSample.css";
import SketchViewModel from "@arcgis/core/widgets/Sketch/SketchViewModel";
const SketchViewModelSample = (props: any) => {
useEffect(() => {
const graphicsWindow = document.getElementById("drawGraphicsWindow") as HTMLElement;
const graphicsLayer = new GraphicsLayer({ title: "sketchviewmodelgraphicsLayer" });
props.impMap.map.add(graphicsLayer);
const svModel = new SketchViewModel({
view: props.impMap,
layer: graphicsLayer
const selectRectangleButton = document.getElementById("create-by-rectangle") as HTMLElement;
selectRectangleButton.addEventListener("click", () => {
props.impMap.popup.close();
svModel.create("rectangle");
expandIconClass: "esri-icon-edit",
view: props.impMap,
content: graphicsWindow,
collapseTooltip : "SketchViewModelSample",
expandTooltip : "SketchViewModelSample"
svModel.on("create", (event: any) => {
alert("Draw completed in SketchViewModelSample !!");
return (
<React.Fragment>
<div id="drawGraphicsWindow">
<div
id="create-by-rectangle"
className="esri-widget esri-widget--button esri-widget esri-interactive"
title="Draw Rectangle"
<span className="esri-icon-checkbox-unchecked" />
</div>
</div>
</React.Fragment>
export default SketchViewModelSample;
Hi @AbdulSamim check to see if you have .wasm configured in your local webserver: https://developers.arcgis.com/javascript/latest/install-and-set-up/#web-server-hosting-configuration
Hi @AndyGup , just confirm you I am not hosted the ArcGIS API for JavaScript instead of that managing the assets locally through help of below URL.
https://developers.arcgis.com/javascript/latest/es-modules/#managing-assets-locally
After following the steps in above URL, under public folder of my project components and esri subfolders are created successfully.
As I mentioned earlier in my query esri sketch, sketch view model and measurement widget graphics are not showing up while using "@arcgis/core": "^4.24.7".
Hi @AbdulSamim these types of errors are typically related to project configuration, and not a bug in the ArcGIS JS API. Please provide a link to a simple github repository that reproduces the issue.
