JSAPI 4.22 IdentifyParameters, layerIds not accepted
1563
02-03-2022 05:40 AM
AndreaKittler
it seems as if in version 4.22 neither the parameter layerIds is accepted in the IdentifyParameters nor the layerOption "visible" is updated.
Example:
I want results from "Vorhaben", layerID 405
https://ims.kiel.de/extern/apps/Vorlage_js4/samples/identify422.html
This still works with version 4.21.
Example:
https://ims.kiel.de/extern/apps/Vorlage_js4/samples/identify421.html
MapImageServer "MIL" with
- Layer "Vorhaben": LayerId: 405, visible: 0
- Layer "Wohnungsbau-Vorhaben": LayerId: 395, visible: 1
Script:
// toggle Visibility
// set IdentifyParameters
// I want results from "Vorhaben"
identifyParams.layerIds = [405];
identifyParams.layerOption = "visible";
view onClick
-> I always (!) get results from layer 395 and never (!) from layer 405
Noah-Sager
Hi @AndreaKittlerthis is a known issue that will be fixed at the next release (4.23). It should also be ready to test on nexthttps://github.com/Esri/feedback-js-api-next.
Here's a potential workaround: https://community.esri.com/t5/arcgis-api-for-javascript-questions/identify-not-honoring-layerids-sup...
Noah-Sager
AndreaKittler
Thank you very much, I didn't found it...
