How do I get individual values back from FeatureLayers on a click event?
7967
15
04-28-2015 10:31 AM
ChrisSergent
I want to be able to get individual values to populate this application: http://maps.decaturil.gov Currently when I click on a point on the map, its displays this:
How would I get just the value of the field OBJECTID for example?
TimWitt2
You can use the onclick event of your feature layer to get any attribute you want:
yourlayer.on("click", function (evt){
  theAttributeYouWant = evt.graphic.attributes.OBJECTID;
Tim
TimWitt2
When you create the layer you can specify it in the outfield property
   layer = new FeatureLayer("//sampleserver6.arcgisonline.com/arcgis/rest/services/Census/MapServer/2", {
"id": "Washington",
"infoTemplate": popupTemplate,
"mode": FeatureLayer.MODE_SNAPSHOT,
"outFields": [OBJECTID],
"opacity": 0.8
ChrisSergent
This is close but I don't want a template, I know how to do that. What I want is to get the individual values so I can take the values and write them to the form below. If I had a line of code  as an example, I could write the code for the other values. Any ideas? :
TimWitt2
Tim
ChrisSergent
I think I am doing it wrong. I wrote this:
app.citizenRequestLayer.on("click", function (evt) {
            myObject = evt.graphic.attributes.OBJECTID;
and I get: Uncaught ReferenceError: myObject is not defined
TimWitt2
What happens if you leave app. off. just have it as citizenRequestLayer.on?
ChrisSergent
That won't work. app is an object for the purpose of unobtrusive JavaScript, so it's needed.
TimWitt2
You need to make sure that myObject is globally defined.
ChrisSergent
It is.
KenBuja
MVP Esteemed Contributor
Where are you defining the variable "myObject" and where do you get the error? Is it in the click callback or somewhere else?
