Getting the Webstyle symbols
2307
06-26-2023 01:02 AM
KarthikeyanShanmugam
Hello
I am trying to render the list of the available webstyle symbols (https://developers.arcgis.com/javascript/latest/visualization/symbols-color-ramps/esri-web-style-sym...) outside the map. Is there any api which I can access to get the webstyle symbol thumbnail and the name.
Any suggestions would be helpful.
Thank you.
2 Solutions
Sage_Wall
Hi @KarthikeyanShanmugam ,
You can use the symbolUtils.RenderPreviewHTML  method to generate a preview image of any symbol in any DOM element.  Here is a simple codepen showing it in action. https://codepen.io/sagewall/pen/XWyparb
AnneFitz
I'd also recommend looking at this Adjust marker placement in polygon symbols sample, specifically the initializeWebStyles function on line 271. This demonstrates how you can use esri/request to fetch the Web Style JSON, and use that to find the name and image for each symbol in the style. Hope this helps!
Sage_Wall
AnneFitz
Thank you @Sage_Wall  @AnneFitz . Both of them worked.
