get feature from objectid directly
3219
12-12-2023 08:04 PM
by Anonymous User
Not applicable
Hi, I cannot figure out how to get feature in a layer or layerview from objectid directly, some function like "layerView.getFeatureById(objectid)".  I store the objectids in array but I don't know how to get the features back later. Could you help me, thanks!
Sage_Wall
Hi @Anonymous User ,
There is a method named queryFeatures() on many of the layer types where you can pass in a Query object defining a query with the object id you are looking for.
https://developers.arcgis.com/javascript/latest/api-reference/esri-rest-support-Query.html
https://developers.arcgis.com/javascript/latest/api-reference/esri-layers-FeatureLayer.html#queryFea...
You'll first need to define a Query and then pass that query as a parameter into queryFeatures().  One thing to look out for is the casing for the ObjectID field can be different depending on the environment hosting the service. So you might want to log out the layers fields or look at the REST enpoint of the service to match the casing for ObjectID. (OBJECTID, ObjectID, etc...)
const query = new Query();
query.where = "OBJECTID = 49"
layer.queryFeatures(query).then((results) => {
  console.log(results.features);
Sage_Wall
JoelBennett
MVP Regular Contributor
Everything said here is accurate, but the nuances of the OID field name can be avoided by using query.objectIds instead of query.where.
by Anonymous User
Not applicable
Thank you both!
AndyGorman
This was helpful. I'm working only with JS API with our own GeoJSON data (not using ArcGIS portal or anything). The "nuances of the OID field" have been driving me crazy.
