Definition expression Date Field Query Issue with Map Service Sublayers in ArcGIS API JS
1118
02-18-2025 04:17 AM
MahmoudAdel1
I have a strange issue related to set a complex definition expression with date field queries to mapservice subLayer the issue was introduced with me in arcgis sdk with ios and with kotlin as well
and then I have made sure this is not related to the sdk itself so I have tried with arcgis js api and I found out this:
- for setting the expression that includes date time queries to feature layer it works well as expected
-for setting the expression that includes date time queries to map service sublayer it doesn't work as expected at all and it returns all features in layer
var dynamicMapServiceLayer = new FeatureLayer({
url: "https://myhost/server/rest/services/App/app/MapServer/1",
definitionExpression: "USER_NAME = 'test' AND (SIGHTING_DATE >= DATE '2025-02-17' AND SIGHTING_DATE < DATE '2025-02-18')"
var dynamicMapServiceLayer = new MapImageLayer({
url: "https://myhost/server/rest/services/App/app/MapServer",
sublayers: [
visible: true,
I guess it is an issue with server of how to process definition expression for both
I hope to resolve this issue soon
MahmoudAdel1
I found a solution for this. The reason why this issue is our used database is SQL Server so the syntax for definition expression [for date time] is not proper for SQL Server in export map service request so when I use this:
 "USER_NAME = 'test' AND SIGHTING_DATE BETWEEN  CAST('2025-02-17' AS DATE ) AND CAST('2025-02-18' AS DATE))"
MahmoudAdel1
