I have created a dijit dialog that contains a TabContainer with several ContentPanes. When it displays, the first ContentPane will not display any contents. Then I added a new ContentPane just to test. Then the new ContentPane won't display contents but the second panel, which was in the first position, will display. So the question is why won't the first ContentPane, currently Pane "X" display correctly? This is just in the deveopment stage so there no code yet.
I just cut a couple of pane to make this post shorter so ther mabe a couple of "</div".
<div id="dialogSearch" data-dojo-type="dijit.Dialog" title="Search for" class="nonModal">
<div style="width: 800px; height: 300px">
<div data-dojo-type="dijit/layout/TabContainer" >
<div data-dojo-type="dijit/layout/ContentPane" title="X" >
<div data-dojo-type="dijit/layout/TabContainer" style="visibility:visible"; >
<div data-dojo-type="dijit/layout/ContentPane" title="By Address1" >
Address Search Parameters go here....
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="By ZipCode1" >
ZipCode Search Parameters go here....
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="By County UPC1" >
County UPC.
</div>
</div>
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="Property" >
<div data-dojo-type="dijit/layout/ContentPane" title="By Address">
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="By ZipCode">
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="By County UPC">
County UPC.
</div>
</div>
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="Water Utilities">
<div data-dojo-type="dijit/layout/ContentPane" title="Water Features">
Water Search Parameters go here...
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="Reclaimed Water Features">
Reclaimed Water Search Parameters go here...
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="San Juan Chama Features">
San Juan Chma Search Parameters go here...
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="Water Quality Data">
Water Quality Search Parameters go here...
</div>
<div data-dojo-type="dijit/layout/ContentPane" title="Water Leak Data">
Water Leak Search Parameters go here...
</div>
</div>
</div>
</div>
</div>
</div>
</div
