From map.infoWindow, how would you retrieve the layer ID that the currently selected feature belongs to?
1843
10-06-2014 10:14 AM
AustinLasher
When the user selects a feature on the map, I need to know which layer that feature belongs to. I've looked around a little bit through logs and on the API, but I haven't found a way to locate this. I suspect there's a simple answer, but I haven't been able to find it yet.
JakeSkinner
Esri Esteemed Contributor
Hi Austin,
Take a look at this JS Fiddle.  When you click on the cities feature layer, a pop-up will display showing the feature layer ID.
JakeSkinner
Hi Austin,
KenBuja
MVP Esteemed Contributor
Your Fiddle was missing a closing "});". Fixed here.
JakeSkinner
Thanks, Ken.  Thought I fixed that, must have forgotten to hit update.
AustinLasher
Thanks a lot, I appreciate the accompanying JSFiddle. Very helpful!
