Find layers by querying groupCategories through Portal
1211
02-07-2024 08:44 AM
MichelleStuart
Hi,  I would like to query our portal for group items by category.
After loading the portal and finding the group by id, I am giving the group to this function as group0:
const getLayers = async (group0: any) => {
  let queryParams = {
    query: `categories: ["/Categories/CDC Social Vulnerability Index/Theme 1: Socio-economic"]`,
  const { results } = await group0.queryItems(queryParams )
  return results
I have tried several iterations of this search string.  If I am only searching one category level (/Categories/ALICE Households), it works , but if I go into a nested category (like Theme 1 here), it returns all of the layers in the group.
I have tried categories: and groupCategories:, with curly braces, with brackets, with no braces, just a string, with quotes and without.  Has anyone had any success fetching layers that have been categorized in a portal group in a nested category schema?
With gratitude,
Michelle
LaurenBoyd
Hi @MichelleStuart -
Instead of using the query property, have you tried using the PortalQueryParams categories property? This takes a string or an array of strings that can be formatted like so:
let queryParams = {
  categories: [
    ["/Categories/Trending/New and noteworthy", "/Categories/Basemaps/Reference maps/Test category"]
 If attempting to get items in a subcategory, be sure to add those category folders the to full path.
Here's an example CodePen that queries two different categories that contain sub categories: https://codepen.io/laurenb14/pen/wvOYvWv?editors=1000
Hope this helps!
Lauren
LaurenBoyd
let queryParams = {
  categories: [
Hope this helps!
Lauren
MichelleStuart
Thank you Lauren! This worked.  I really appreciate your help.
