esri.views.2d.layers.FeatureLayerView2D] Failed to resolve layer view
5987
08-16-2022 09:59 PM
JayakumarPD
    Using ESRI JS API Core 4.24
     I have created a project on Next JS and trying to load the data(polygon) from a JSON source, which I have kept in a local folder.  I am getting the json from getStaticProps and passing it to EsriMap component using bellow code..
import dynamic from "next/dynamic";
import React, { useState } from "react";
import fs from "fs/promises";
import path from "path";
const EsriMap = dynamic(() => import("../../components/esri_map"), {
  ssr: false,
export default function index({district}) {
  return (
      <EsriMap districts={district}/>
export async function getStaticProps() {
  const filePath = path.join(process.cwd(), "data", "district.json");
  const jsonData = await fs.readFile(filePath);
  const data = JSON.parse(jsonData);
  return {
    props: {
      district: data,
 First Try
import React from "react";
import { useRef, useEffect } from "react";
import ArcGISMap from "@arcgis/core/Map";
import MapView from "@arcgis/core/views/MapView";
import LayerView from "@arcgis/core/views/layers/LayerView";
import SpatialReference from "@arcgis/core/geometry/SpatialReference";
import FeatureLayer from "@arcgis/core/layers/FeatureLayer";
import Polygon from "@arcgis/core/geometry/Polygon";
import Graphic from "@arcgis/core/Graphic";
import SimpleFillSymbol from "@arcgis/core/symbols/SimpleFillSymbol";
import SimpleLineSymbol from "@arcgis/core/symbols/SimpleLineSymbol";
import Color from "@arcgis/core/Color";
import SimpleRenderer from "@arcgis/core/renderers/SimpleRenderer";
import Sidebar from "./sidebar";
export default function EsriMap({ districts }) {
  var map, view;
  const mapRef = useRef(null);
  const {
    displayFieldName,
    features,
    fieldAliases,
    fields,
    geometryType,
    spatialReference,
  } = districts;
// I am getting features properly
   console.log(features);
  useEffect(() => {
    const map = new ArcGISMap({
      basemap: "topo-vector",
    const view = new MapView({
      map,
      container: mapRef.current,
      extent: {
        spatialReference: {
          wkid: 102100,
        xmax: 9318041.682582326,
        xmin: 7685897.199114412,
        ymax: 2134999.5715922136,
        ymin: 1257953.6118566156,
      zoom: 7,
// like this i can add the map service also, so scope is fine
    // const districtLayer = new FeatureLayer({
    //   url: "http://XXXXXXXXXXXXXX/MapServer/1"
    // map.add(districtLayer);
    const districtFeatureLayer = new FeatureLayer({
    objectIdField:"OBJECTID",
    geometryType:geometryType,
    fields:fields,
    spatialReference:spatialReference,
    source:features,
    map.add(districtFeatureLayer);
  return (
      <div className="flex flex-row h-full">
        {/* <aside className="w-1/5">Table of content</aside> */}
        <Sidebar/>
        <div className="w-4/5" ref={mapRef}></div>
      </div>
It is giving the error like this (firsttry.png enclosed)
  1. error: s
    1. details: {layer: l, error: s}
    2. message: "layerview creation failed"
    3. name: "layerview:create-error"
Second Try
var graphicsD =[
    {geometry:
        {features:features,
        geometryType: geometryType,
        spatialReference: new SpatialReference(spatialReference)},
        attribute:fields
  let featureD = [
      spatialReference:new SpatialReference(spatialReference),
      fields:fields,
      source: graphicsD,
  let layerD = new FeatureLayer({
    title:"s",
    source:featureD,
  map.add(layerD);
It is giving error like this(secondtry.png enclosed)
  1. error: s
Can anybody guide where I am committing a mistake.  in feature layer creation or preparing data for feature layer creation.
JayakumarPD
In ESRI JS API 4.24, using the json data, feature layer can be created using bellow code.  Which renders, with default symbology, the symbology can be changed using renderer or json.
const {features,fields,geometryType,spatialReference} = districts;
var districtsFeatureLayer = new FeatureLayer({
      source: features.map((feature) => {
          return {
              attributes: feature.attributes,
              geometry: {
                  type: 'polygon',
                  rings: feature.geometry.rings,
                  spatialReference: new SpatialReference({ wkid: spatialReference.wkid })
      outFields: ["*"],
      objectIdField: "OBJECTID",
      geometryType: "polygon",
  map.add(districtsFeatureLayer);
JayakumarPD
Hi this is the json file with one ring, after reading the file, if I console log the features, I am getting the bellow results, screen shot provided.
console.log(features[0].geometry.rings);
console.log(features[0].attributes);
  "displayFieldName": "OBJECTID",
  "fieldAliases": {
    "FID": "FID",
    "OBJECTID": "OBJECTID",
    "KGISDistrictCode": "KGISDistrictCode",
    "KGISDistrictName": "KGISDistrictName",
    "BhuCodeDis": "BhuCodeDis",
    "SHAPE_Leng": "SHAPE_Leng",
    "SHAPE_Area": "SHAPE_Area"
  "geometryType": "esriGeometryPolygon",
  "spatialReference": { "wkid": 102100, "latestWkid": 3857 },
  "fields": [
    { "name": "FID", "type": "esriFieldTypeOID", "alias": "FID" },
    { "name": "OBJECTID", "type": "esriFieldTypeInteger", "alias": "OBJECTID" },
      "name": "KGISDistrictCode",
      "type": "esriFieldTypeString",
      "alias": "KGISDistrictCode",
      "length": 2
      "name": "KGISDistrictName",
      "alias": "KGISDistrictName",
      "length": 30
      "name": "BhuCodeDis",
      "alias": "BhuCodeDis",
      "length": 2
      "name": "SHAPE_Leng",
      "type": "esriFieldTypeDouble",
      "alias": "SHAPE_Leng"
      "name": "SHAPE_Area",
      "alias": "SHAPE_Area"
  "features": [
      "attributes": {
        "FID": 0,
        "OBJECTID": 1,
        "KGISDistrictCode": "01",
        "KGISDistrictName": "Belagavi",
        "BhuCodeDis": "01",
        "SHAPE_Leng": 1008729.89777,
        "SHAPE_Area": 13393941679.9
      "geometry": {
        "rings": [
            [8272602.8877369082, 1781168.6974798122],
            [8271469.4757582778, 1780253.2798111972],
            [8270580.2308112225, 1780944.2739405686],
            [8269718.4766434291, 1780156.0765665986],
            [8267308.2561494801, 1781289.4170124291],
            [8267541.7231793851, 1783341.4453024301],
            [8266906.8653022703, 1784976.7043788226],
            [8270213.8552803472, 1785299.7014001305],
            [8272040.7979063801, 1781933.3299525555],
            [8353622.22053569, 1857373.9843678209],
            [8353549.6284096939, 1855612.880076559],
            [8353126.1126473341, 1855648.7738658153],
            [8386293.7881848402, 1906019.5947838936],
            [8386550.1827982003, 1905677.2375666345],
            [8388904.4673479851, 1905831.8356136479],
            [8392877.1667051669, 1904651.9076249683],
            [8391155.7702609934, 1900359.169648292],
            [8391099.089991495, 1897680.1704191524],
            [8391863.6651064064, 1893178.7134605984],
            [8389923.8108037319, 1892927.6723799561],
            [8389242.7971151508, 1887629.1679924545],
            [8384396.4850854063, 1888080.61527206],
            [8381158.4870982636, 1887670.7634962332],
            [8378513.5037490968, 1885133.3278914453],
            [8378218.2520170556, 1883650.0002705336],
            [8378804.0561771225, 1879032.4739152917],
            [8378119.4533742433, 1876793.1910269139],
            [8377395.1903978232, 1876362.2611853536],
            [8377603.0505169211, 1875136.5911601887],
            [8376839.6625328436, 1874902.5029742045],
            [8374889.1659543682, 1875933.1707916982],
            [8373138.6076304596, 1876042.6343794444],
            [8368544.7447276767, 1874579.3442661844],
            [8366640.4789980426, 1872708.1000699773],
            [8366649.8632083358, 1870500.4811883054],
            [8367486.142839537, 1868888.9085742568],
            [8367121.5867228284, 1866657.6199670509],
            [8366259.2288290234, 1865860.5857114836],
            [8363656.4193517203, 1865186.5271695261],
            [8362169.0248884615, 1863415.6034352882],
            [8360580.3934960216, 1863962.8007285998],
            [8360022.2125425451, 1865847.4157801187],
            [8358913.9057112262, 1867174.9378652482],
            [8358506.6635034578, 1869071.6464210702],
            [8357197.0996044502, 1870289.4883449806],
            [8356846.2058340823, 1870307.1919624726],
            [8356121.8302684864, 1867303.1159761033],
            [8349775.5362827796, 1867134.0033447875],
            [8347647.2728283638, 1862599.4585533165],
            [8347403.7682493683, 1858742.4260026976],
            [8348110.6873558806, 1857336.9731950711],
            [8350388.0357843759, 1857862.0858826991],
            [8350891.3969007712, 1855799.7838201199],
            [8352214.9171146154, 1854928.1656598989],
            [8357534.8155315639, 1855252.4260752592],
            [8356977.3083775751, 1851709.5775170021],
            [8353193.7164362157, 1850388.2228654576],
            [8352692.4254798926, 1847305.2209906138],
            [8352772.7939832052, 1843939.4227745044],
            [8353687.1563432962, 1842067.0440357365],
            [8355277.8230452323, 1843099.8247419267],
            [8356271.1311455267, 1842515.5123817781],
            [8357523.9539731275, 1843198.9432300299],
            [8359605.5122776171, 1842377.961776614],
            [8363516.8887414308, 1843086.8369165075],
            [8364277.2906441512, 1842238.68265811],
            [8363334.0670273034, 1839050.0473262633],
            [8363475.8412601193, 1837956.2491287724],
            [8371855.7676992649, 1836272.1444266855],
            [8375006.822747251, 1834696.9860198612],
            [8375388.0848793518, 1833550.9803902295],
            [8374539.6707010763, 1831545.4825372933],
            [8374830.4308871906, 1829012.9048220334],
            [8376711.1731165191, 1828397.7549056148],
            [8379098.0980127063, 1828741.2685245813],
            [8380894.9534691609, 1827817.2237500504],
            [8380722.3038031766, 1825305.3449123022],
            [8381453.4781243997, 1824432.4245240653],
            [8379747.2697022641, 1818655.4805192777],
            [8385395.7122262185, 1818126.8883753009],
            [8388077.6742700785, 1819404.5480906523],
            [8388808.1657901928, 1818014.0963751394],
            [8393606.7163973562, 1817865.6479810155],
            [8394840.1987443715, 1819814.2136331035],
            [8395528.4884636309, 1816657.4866866642],
            [8396470.9501935132, 1816051.261638646],
            [8396853.6653246749, 1814188.6298099705],
            [8396543.9262496624, 1811661.8289408551],
            [8395296.1187427584, 1810764.0861299597],
            [8395313.5523013882, 1808810.3769972357],
            [8396104.3257780299, 1808175.8677632085],
            [8396563.472292969, 1805605.7795920055],
            [8397713.9856765773, 1805267.6614203763],
            [8396971.9186600074, 1801613.1152235474],
            [8397858.6522823628, 1800604.2268129189],
            [8396348.2063281741, 1795933.3871394899],
            [8397954.1148338448, 1795038.8396700539],
            [8397641.1329530571, 1792563.1077690122],
            [8399018.0986190643, 1791662.5413769481],
            [8399197.8497667089, 1789109.8391584232],
            [8399910.1358206049, 1788333.1916714669],
            [8399924.2329645585, 1783790.5739243519],
            [8398826.7175524663, 1781037.5725429768],
            [8397812.6041097902, 1780672.3728382769],
            [8397400.9760561436, 1779091.0319765029],
            [8395116.9193341881, 1779960.6547151504],
            [8396176.0446468387, 1784636.148360878],
            [8396096.0649320949, 1786472.9668754176],
            [8391849.2603907492, 1786033.5565077602],
            [8390730.7657889128, 1786740.2324729387],
            [8389585.414699953, 1782205.9305760455],
            [8389200.876170747, 1782074.6116688119],
            [8387151.2193799624, 1782113.7623732821],
            [8386447.0688729715, 1784680.7044425288],
            [8385909.3559082188, 1784473.7184684393],
            [8385977.4304108899, 1783600.13705316],
            [8385339.6845808662, 1783072.8281382248],
            [8382691.8039409108, 1783010.0813522963],
            [8382952.600730367, 1777766.7531037934],
            [8384317.8191332174, 1777100.1641625543],
            [8384305.1071421113, 1775123.9520722157],
            [8383933.0884869648, 1773727.1378196196],
            [8382335.459472863, 1773222.1652196599],
            [8381557.8201281438, 1773525.0463535918],
            [8381395.330195507, 1774781.3723131479],
            [8379600.7969054226, 1774710.7907239588],
            [8379967.7232655631, 1768850.793304973],
            [8379105.2776410421, 1764016.3719821146],
            [8376626.9625618439, 1763986.4439141725],
            [8374947.9856715696, 1767549.568850752],
            [8373327.3669156618, 1767394.8583507002],
            [8373096.7355191242, 1767815.7192177954],
            [8371831.9223620119, 1767864.3739734187],
            [8371237.9801729489, 1764140.3255568163],
            [8369920.0795269618, 1764141.8257073157],
            [8369516.9160979372, 1764895.8792731743],
            [8367982.8179639103, 1765402.6315711299],
            [8363654.0983568905, 1765459.7467955926],
            [8362576.5785381086, 1766385.5999550861],
            [8361197.561997571, 1766711.3411413573],
            [8360110.8401890108, 1765243.1305554318],
            [8359060.7653124267, 1759535.8745707194],
            [8357775.6530478448, 1761076.1703704356],
            [8356348.5412360076, 1761389.4453423512],
            [8355204.7302303286, 1762412.0661891513],
            [8355973.236881366, 1766378.0402795104],
            [8355292.872523318, 1768052.330022719],
            [8354446.4870927846, 1767763.8079987972],
            [8354051.1791431839, 1766581.6442493373],
            [8352281.2446367163, 1766535.9529282381],
            [8352019.7764505334, 1764549.3448586038],
            [8351156.0380506553, 1763721.2149302191],
            [8348029.3130882932, 1764337.1668898943],
            [8345269.2134009507, 1764411.0987058105],
            [8344730.6522206981, 1761477.4528629202],
            [8341468.7699479563, 1761064.2958944351],
            [8339226.38356297, 1761969.5913106229],
            [8336810.5971290944, 1761968.7269433376],
            [8335186.3064985638, 1760382.8086433597],
            [8332899.2361939419, 1759860.194887314],
            [8331659.6661816044, 1759363.5211781303],
            [8330828.9723986071, 1759806.898487736],
            [8329946.0524942074, 1759472.9472017318],
            [8329992.1255572448, 1757712.930867828],
            [8330917.6761340071, 1755370.6593701541],
            [8329651.2244217284, 1754917.1235961795],
            [8327347.276384661, 1752663.1045595403],
            [8326599.3273126632, 1752488.0989050565],
            [8327882.6051613186, 1749428.4411673504],
            [8328094.7327776318, 1747585.8446463486],
            [8327104.7865399541, 1746488.8630648274],
            [8325280.3647458991, 1745274.7945371305],
            [8324389.4174294127, 1742399.6406089237],
            [8322947.8972502667, 1743674.172951709],
            [8322292.8813560111, 1743629.5991127952],
            [8320851.6741043413, 1746344.3337945088],
            [8320298.9885024764, 1746213.7023340999],
            [8318560.6837212481, 1745279.1670250339],
            [8319141.72442172, 1743348.7342836182],
            [8320348.4855056759, 1742691.7893949],
            [8320287.9323398927, 1741476.8495190276],
            [8318941.2907969169, 1738936.9504269951],
            [8320098.3171305982, 1737461.0807725396],
            [8320121.7057329342, 1736675.3783124487],
            [8319414.5829216074, 1736318.1223587268],
            [8315322.3628417207, 1736387.7434587756],
            [8314333.0821601078, 1735188.7514768944],
            [8309892.7909112098, 1734247.7985366322],
            [8308436.3535122545, 1731798.3618290753],
            [8305969.821345143, 1730642.1605144092],
            [8301653.4150204221, 1734348.7515994266],
            [8300673.2456976669, 1735802.1845283243],
            [8298323.3157337299, 1737114.3664532613],
            [8297189.1245222054, 1737438.5024611952],
            [8295136.8941772114, 1735574.7777720736],
            [8294387.1246318026, 1735718.9416235159],
            [8293984.2381084124, 1736783.9055559954],
            [8294373.5461353697, 1738525.8301065501],
            [8293005.5246985415, 1739640.4200555023],
            [8291869.9691530634, 1739815.6995021387],
            [8291264.0347377881, 1738846.6721759178],
            [8290663.6586516388, 1738730.6349420126],
            [8289148.9435277442, 1738986.5149867758],
            [8287460.2117463183, 1737761.235042426],
            [8287702.1475555459, 1736173.1847179013],
            [8286429.6375576658, 1735806.2747040556],
            [8285762.1881574299, 1734937.2783601566],
            [8284750.2603164231, 1737808.8398822818],
            [8284633.2378056804, 1742619.7983739099],
            [8283520.3279576022, 1743909.4707119775],
            [8280709.002708164, 1744828.7422985074],
            [8279232.2047484284, 1744530.6748860592],
            [8275853.0656073922, 1748903.0905281859],
            [8273926.0132203372, 1748786.4776017291],
            [8270007.9355223067, 1749607.7552968787],
            [8268641.6477225805, 1749371.2492685632],
            [8269029.9403053056, 1750420.9503426517],
            [8268550.668932884, 1752209.1682728061],
            [8266994.8319142405, 1754059.6056780182],
            [8266424.6845651511, 1753911.2716491933],
            [8265395.0349895125, 1754581.5620669147],
            [8265326.8356034178, 1755997.2876278758],
            [8266417.5770280445, 1757568.1326632993],
            [8267033.5069846045, 1760299.8359730719],
            [8266124.4070571652, 1761266.0645902699],
            [8265018.3490040842, 1761107.285063528],
            [8265695.3186661107, 1764627.0335320304],
            [8264053.0855190838, 1766059.9285848844],
            [8262415.7999424981, 1766289.8948252019],
            [8261897.7678927742, 1765747.1275025224],
            [8262441.3931233259, 1764903.1214445441],
            [8260520.803160564, 1764270.5518608906],
            [8260421.9046867136, 1765743.5857274118],
            [8258669.2114909431, 1766056.8166870798],
            [8258386.125132909, 1767005.3350841985],
            [8258796.3587666722, 1767381.0770249411],
            [8257818.9185108393, 1767877.3290621622],
            [8256186.3182028383, 1766755.0906314193],
            [8255867.8631618563, 1764723.8112573966],
            [8252788.7015547026, 1764099.1941958384],
            [8248863.9767134385, 1765074.7610880178],
            [8247265.8087878814, 1766548.5504449036],
            [8247679.8850756781, 1766979.7673689513],
            [8249709.8599253315, 1766788.5565647357],
            [8251405.560314361, 1767679.1056282984],
            [8252495.2626145715, 1770373.6821846485],
            [8251780.8674428668, 1772195.4899485477],
            [8251247.54974123, 1772419.5202919187],
            [8254289.8879743209, 1774125.9601954685],
            [8255382.6482447861, 1775725.339587962],
            [8257996.8049892318, 1775959.1949251301],
            [8260199.87345374, 1776748.1085970313],
            [8260853.3084045993, 1779137.889510619],
            [8261925.2760801744, 1779884.3459352562],
            [8263122.2074525803, 1780318.0950187217],
            [8263512.7675362257, 1780033.958746894],
            [8263774.3621714357, 1779156.0353401515],
            [8263033.2756234827, 1777800.5159198914],
            [8263041.3825992495, 1776550.6661632112],
            [8264492.5018129926, 1774994.3757871022],
            [8267436.2909981636, 1776163.9703333387],
            [8269664.0696260976, 1774779.1139573469],
            [8271849.0837326655, 1775727.4124552803],
            [8273048.9536910476, 1776934.8553332216],
            [8273497.7223059991, 1778237.9548527023],
            [8275541.4999025017, 1777485.477127742],
            [8277030.8111431468, 1778233.2032877365],
            [8278571.0988826891, 1779902.0497313875],
            [8278972.0489982506, 1781896.1969192023],
            [8278130.6105877059, 1783729.4528421541],
            [8280327.5284198625, 1786382.4636540436],
            [8280284.6095384508, 1787219.508113943],
            [8275874.3945187917, 1787469.3885428323],
            [8275767.1467437558, 1788186.8221597939],
            [8278029.5667909654, 1790400.2294467366],
            [8278221.655798356, 1792402.6223435206],
            [8279671.7237094762, 1790982.1812098701],
            [8280745.6080507692, 1788148.7994449157],
            [8281785.4862711122, 1787500.4832041305],
            [8282843.300067923, 1788094.393794196],
            [8282910.9628141494, 1788817.958108268],
            [8281575.1974325152, 1790327.6984211036],
            [8281550.0279678237, 1792963.4974163226],
            [8280740.5424581785, 1793772.2864615708],
            [8285602.2685546661, 1799712.8486658954],
            [8286992.2271011556, 1803069.7925856845],
            [8287183.2818869306, 1804919.4639021319],
            [8289214.4181471746, 1809417.2935003415],
            [8289176.3797111847, 1810438.1552801048],
            [8288515.802006986, 1810233.3300076833],
            [8285741.8566295728, 1811508.0784731412],
            [8283812.9416263336, 1811112.3939811368],
            [8280093.7235241234, 1808854.4138522574],
            [8278903.0429893825, 1809190.8117379632],
            [8279818.8547682669, 1810952.6513798363],
            [8277974.5444261339, 1810765.6218861872],
            [8277854.4545466509, 1811149.5073170734],
            [8279522.7494788729, 1813821.4447743832],
            [8280774.0744360117, 1814170.7471831001],
            [8281301.6610702733, 1815193.9806079026],
            [8283067.0482124276, 1815693.6956817599],
            [8283393.7190224929, 1816618.2744269059],
            [8285225.7423127359, 1817758.2958150944],
            [8286975.5017811079, 1816960.7306483542],
            [8288724.89752784, 1816868.4677844027],
            [8288765.780090984, 1816352.050572613],
            [8290308.0337153152, 1815239.10081735],
            [8291521.3334765127, 1815247.0892866061],
            [8292311.3408886325, 1817588.7813135211],
            [8291612.4279111745, 1821203.300112746],
            [8291045.7402204312, 1821841.1116583124],
            [8292051.9530827543, 1823150.3942104513],
            [8292304.7501874911, 1825699.2172814996],
            [8292720.9777152305, 1826391.1789198385],
            [8294052.7505174642, 1826850.6076480958],
            [8294063.1739485282, 1828001.1053592344],
            [8292833.8577362411, 1829343.9602915642],
            [8293468.3564945171, 1830936.7440854444],
            [8291082.0797830196, 1833615.2005721894],
            [8289521.9432431525, 1832589.6451008068],
            [8288407.8277642438, 1833046.2303260528],
            [8287952.3476272579, 1834009.8123195365],
            [8286381.4207482729, 1833844.0205589843],
            [8286247.2701307759, 1834409.1973633501],
            [8284074.8068834404, 1834820.5744488793],
            [8283881.6302000191, 1837262.5432731262],
            [8283416.4035756588, 1837616.1404929103],
            [8280812.7243962632, 1836973.1170092898],
            [8280205.9839024106, 1838536.5366563608],
            [8279390.1511808196, 1839005.963011564],
            [8276008.1985948943, 1838615.8923022819],
            [8276913.5745989913, 1837371.9511467007],
            [8276585.487418713, 1836806.3352830112],
            [8274171.7930915197, 1835806.9635795054],
            [8273648.7190020764, 1837842.3808942274],
            [8274142.9731708597, 1838560.4103772948],
            [8274909.1462458801, 1838327.1083334342],
            [8275752.3786755484, 1838873.495360092],
            [8275501.3222343121, 1839795.5510305671],
            [8273804.0080361078, 1841387.3208594315],
            [8274761.573619131, 1841824.6600778126],
            [8274393.6657400709, 1842507.297196805],
            [8273403.1332995798, 1842147.6546382301],
            [8272674.1332844635, 1842565.5521362987],
            [8273361.1429640269, 1843151.7090017439],
            [8272938.6312183226, 1844346.6881036172],
            [8274077.3909140984, 1844389.026107712],
            [8273004.7418888574, 1845653.6990731577],
            [8273786.3325392157, 1846221.5997593647],
            [8273271.0334788309, 1848303.8882126682],
            [8274145.3171974579, 1849173.4106745177],
            [8274076.3369865194, 1849928.2925369802],
            [8275122.9031704711, 1850271.9799756082],
            [8276354.1040893476, 1847277.4900382215],
            [8276770.2267545694, 1847265.9067813372],
            [8278074.3560397904, 1851505.8500637349],
            [8276783.4984356072, 1851839.0578349729],
            [8274926.0255547995, 1851484.8420883545],
            [8274250.8926931713, 1853365.6047334902],
            [8275069.7439313149, 1854674.9413445315],
            [8274399.2943941085, 1857528.2857858005],
            [8272476.4993458372, 1857254.3773221173],
            [8270692.8391477708, 1858515.312354486],
            [8269918.0492207306, 1858408.2538072681],
            [8270091.252567512, 1863066.7318994612],
            [8268720.9828071864, 1863111.9794916159],
            [8268024.3255549381, 1860847.9335341854],
            [8266829.7447100114, 1860389.4862458757],
            [8265500.6354523748, 1862060.4546618883],
            [8265572.9202326862, 1862655.2395765651],
            [8268602.5595846316, 1863418.1839613121],
            [8268347.3237309698, 1864954.2531440407],
            [8267616.6981919166, 1865417.4673414335],
            [8267059.6621303717, 1867279.0769012759],
            [8267320.4488596134, 1867741.7066068796],
            [8267745.6804781491, 1868276.1106331774],
            [8268671.2548340484, 1867824.5160535942],
            [8269069.6217538938, 1865943.9952603623],
            [8269518.7274735225, 1865785.1616491296],
            [8270210.0830150871, 1866548.2732627266],
            [8271243.5846219379, 1866064.4017569751],
            [8271899.6930583054, 1863159.877296115],
            [8272765.9987724936, 1863399.8280586628],
            [8272847.3842556439, 1868836.1912961081],
            [8273705.2162845777, 1869375.1687196533],
            [8275278.8746159887, 1868393.0545696614],
            [8277399.9045157023, 1869580.7080814857],
            [8277576.2759114308, 1867376.579788306],
            [8280094.5075164409, 1866115.8030530147],
            [8280777.875174012, 1866996.57360854],
            [8280869.5719024148, 1869824.1757916696],
            [8281973.7229743823, 1872359.5217752978],
            [8284635.521916694, 1872535.9991357499],
            [8285097.8507976802, 1873842.6752141432],
            [8286085.4111971762, 1874418.9486020503],
            [8289450.050846858, 1874920.2556572556],
            [8289494.709671271, 1877126.9011707702],
            [8288429.3262426388, 1879917.1695112209],
            [8288506.3352055606, 1880612.6751204205],
            [8289973.9359264262, 1881827.2193742418],
            [8290540.8522118349, 1879833.1914201481],
            [8292191.4946303982, 1877830.8318863262],
            [8298269.650666195, 1878240.6065975528],
            [8298293.7592787957, 1873779.1286683786],
            [8299674.5210827235, 1873802.3374831853],
            [8300709.4867111836, 1872719.6800442555],
            [8299467.9099991983, 1870428.0667673342],
            [8301131.6728403009, 1869196.8680858666],
            [8302432.2316438565, 1869577.8636373256],
            [8303181.7399947606, 1870422.5960636912],
            [8304681.992121771, 1870382.9489274318],
            [8306787.1511873035, 1872338.4777169146],
            [8307769.7972242339, 1871891.9017612152],
            [8308220.3820178024, 1872414.9375920084],
            [8308131.7673731307, 1875107.4863029665],
            [8308893.52321178, 1875759.4746902967],
            [8311133.7806189926, 1874911.1923064562],
            [8312469.75603469, 1875535.4229649275],
            [8313784.3518536435, 1875309.4763483019],
            [8314230.1020290451, 1875701.0052737859],
            [8313781.4719323199, 1876542.7790738265],
            [8310798.0579029443, 1877986.9584704335],
            [8310357.3507903377, 1878868.4967736595],
            [8311630.3291043499, 1881700.1632850645],
            [8313194.9763355711, 1881997.2332709779],
            [8313374.4504528781, 1882862.4891297524],
            [8314334.4506246764, 1883477.4439996877],
            [8313474.6874182159, 1884120.6014812938],
            [8314353.3382901829, 1884765.2955795296],
            [8314461.1979840342, 1887911.3586105152],
            [8318492.4761980493, 1887899.4032547339],
            [8321440.5248726616, 1889659.3265770224],
            [8323736.7361747995, 1891863.5245238682],
            [8326254.7068079198, 1891524.4192458862],
            [8326502.2262850916, 1892179.7429877666],
            [8331629.4934569634, 1893141.0200215536],
            [8332493.6316393837, 1894209.7186159096],
            [8333806.3988327365, 1893480.1869826727],
            [8334603.7227872312, 1894525.0599396804],
            [8339993.5746261533, 1894387.3707920008],
            [8338978.4648386165, 1896372.6402240663],
            [8338926.1036870535, 1901860.2064819741],
            [8338256.1501962822, 1904867.3438511728],
            [8340323.0176096503, 1904958.6378979932],
            [8340766.8104772605, 1905956.5893815963],
            [8341748.1862405641, 1905809.6593749868],
            [8341792.0446754908, 1906736.574364993],
            [8342211.6599280061, 1906925.4945382315],
            [8344549.0730582643, 1907041.5525357458],
            [8344861.1368718734, 1909998.9961012276],
            [8344093.7507033302, 1909808.3647184509],
            [8343737.3702639788, 1910408.8147334969],
            [8342739.1169422092, 1910456.3924242551],
            [8341599.5848065251, 1911979.0499890526],
            [8340452.7482857015, 1912532.0924787631],
            [8340374.6235899068, 1913428.977760704],
            [8341418.2015702361, 1914395.9862766797],
            [8342913.8195896428, 1913903.3056753671],
            [8344429.1154426085, 1912421.2230020401],
            [8344477.6020868542, 1913516.6798413927],
            [8345275.7852444565, 1914820.4280985582],
            [8348238.3589626187, 1915262.4286395996],
            [8351964.4166985694, 1914228.1240479539],
            [8351830.0028273351, 1912529.2136445746],
            [8353839.9173260722, 1914045.1113068666],
            [8356029.1905391989, 1914105.3798172681],
            [8357255.8092028284, 1915055.4921624942],
            [8358664.1291840132, 1915270.3237400092],
            [8359614.9155735336, 1910951.6567421372],
            [8361963.459511078, 1910756.506580231],
            [8362476.422339851, 1909379.8798039879],
            [8363609.8720403183, 1908714.1353800381],
            [8364129.228451007, 1906211.9535389263],
            [8367418.2509267572, 1905358.7531977021],
            [8369600.441101281, 1906100.1992601582],
            [8369889.192779283, 1905627.3583053688],
            [8369219.091524573, 1902792.5711055228],
            [8373172.5902966904, 1902429.3887884864],
            [8374403.2424823297, 1902797.9539881176],
            [8375449.6073249904, 1905424.6086502557],
            [8378371.4378355481, 1904894.3152566087],
            [8380447.1695515923, 1907060.3140370937],
            [8381163.2038478609, 1909833.8667771732],
            [8380498.68870096, 1910418.5373492376],
            [8380134.1805403046, 1911946.4834283444],
            [8380306.5796302147, 1915814.0316560098],
            [8386987.3395153405, 1915728.1743072921],
            [8386217.2899032794, 1910732.8852629857],
when I print the features in console, I will get the info like this
and single polygon ring like this
and single attributes like this
then I changed the code to prepare the polygon first and created the feature layer like this
let districtLayer=[{
      geometry:new Polygon({
        rings:features[13].geometry.rings,
        spatialReference: { wkid: 102100 }
      attributes:features[13].attributes
     let districtLayerService = new FeatureLayer({
      source: districtLayer,
    map.add(districtLayerService);
so I could able to render one polygon successfully.  If I have 10,000 polygon, Is there any short circuit to render the all the polygon with out that much iteration.
Is there any way, where I can pass the feature directly to new FeatureLayer class instead of iterating, to render on map.
Tags (1)
JayakumarPD
          return {
              geometry: {
                  type: 'polygon',
      outFields: ["*"],
