Editing the edit web app template
1863
09-19-2014 02:05 PM
by Anonymous User
Not applicable
I downloaded the Esri's Edit web app template for use in AGOL and I'm trying to adjust the height of the table of contents or section of the window that shows the editable features, which originally appears on the left side of the screen. Here is what is looks like now: http://mapservertest.borough.kenai.ak.us/edit-template-master/index.html  If you can't access that then see the image at the bottom, I've circled the area of interest.
Below is a snippet from the index.html file. It shows the width parameter as "240px" by default: setPanelContent(content_title , content , "240px")
But where would the height be? Maybe I'm looking in the wrong location. How is the height determined?
var content = domConstruct.create("div",{id:"editorDiv"});
                //create the Legend or Editor
                var editableLayers = this.appcontent.getEditableLayers(response.itemInfo.itemData.operationalLayers, this.map);
                //edit permissions
                var editable = true;
                var content_title = this.options.i18n.viewer.content_title;
                if(esriLang.isDefined(this.options.userPrivileges)){
                    if(array.indexOf(this.options.userPrivileges, "features:user:edit") === -1){
                        editable = false;
                        //change the title to legend
                        content_title = content_title = this.options.i18n.viewer.legend_title;
                } else if(editableLayers.length === 0){
                this.appcontent.setPanelContent(content_title , content , "240px").then(lang.hitch(this,  function(){
                    this.map.reposition();
                    this.map.resize();
*Snippet from the CreateContent.js file for more context:
setPanelContent: function( title, content, width){
               var deferred = new Deferred();
                if(this.isMobile){
                   dom.byId("displayButton").innerHTML = title;
                   domConstruct.place(content, this.leftPanel);
                   this.mainWindow.resize();
                   deferred.resolve();
                }else{
                  this.leftPanel.set("content" , content);
                  this.leftPanel.set("style", {width: width});
                  deferred.resolve();
                 return deferred.promise;
KellyHutchins
Esri Notable Contributor
Hi Ben,
Try adding the following rule to the layout.css page. You'll want to update the specified height to the value you want.
    .esriTemplatePicker{
      height:800px;
KellyHutchins
Hi Ben,
      height:800px;
