Drawing Line Measurement Not Matching Buffer Distance
1616
09-11-2014 01:54 PM
ChrisSergent
I need a line measurement to match my buffer distance. The code modifications should related to this article: Measuring distances and areas when your map uses the Mercator projection | ArcGIS Blog
Currently I have a buffer that uses a WKID of 4326 which appears to draw correctly with a measured buffer of 500 feet. The rest of the application uses a WKID 102100 which allows the application to display correctly, but the line tool is coming up with a measurement of about 150 feet more than the buffer. I have changed each 102100 one at a time even ones I did not think I should as I need this app to work in testing. Any idea where I am going wrong with my code so that my measurements work?
Here is my code:
/// <reference path="scriptaculous.js" />
/// <reference path="dragdrop.js" />
/// <reference path="effects.js" />
/// <reference path="rico.js" />
/// <reference path="ricoStyles.js" />
/// <reference path="ricoCommon.js" />
/// <reference path="ricoEffects.js" />
// Using Intellisense For The Above
// http: //msdn.microsoft.com/en-us/library/bb385682.aspx
////////// AUTHOR & APPLICATION INFORMATION ////////////////////////////////////////
//   Author: Chris Sergent
//   Date:   May 1, 2012
//   Application: SOA
// Address Points - Layer 0
// Bike Paths - Red Line - Layer 1
// Inhome Daycares - Dark Blue - Layer 2
// Daycare Facilities - Light Blue - Layer 3
// Playgrounds - Purple - Layer 4
// School Property - Green - Layer 5
// Macon Co. Tax Parcels - Layer 6
// Decatur Corporate Boundary - Layer 7
//              DECLARE AND SET VARIABLES BEGIN
//              SET UP DOJO BEGIN
Dojo Framework Require Begin
dojo.require("dojo.parser");
dojo.require("dojo.number");
Parsing dojo.number include four functions
- dojo.number.format() - formats numeric values
- dojo.number.parse() - converts a string to a number
- dojo.number.regexp() - returns a regular expression
- dojo.number.round() - rounds numbers
dojo.require("dojo.data.ItemFileReadStore");
dojo.require("dojo.fx");
dojo.require("dijit.dijit");
dojo.require("dijit.form.Button");
dojo.require("dijit.Toolbar");
dojo.require("dijit.TitlePane");
dojo.require("dijit.layout.BorderContainer");
dojo.require("dijit.layout.ContentPane");
dojo.require("dijit.Editor");
dojo.require("dijit.layout.TabContainer");
dojo.require("dojox.grid.DataGrid");
// Declare Rounding Corners With Rico
var roundCorners = Rico.Corner.round.bind(Rico.Corner);
Dojo Framework Require End
// REST API - Making Tools Available
// ESRI dojo objects
// allows you to work with the dynamic map service resource exposed by the ArcGIS REST API.
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/arcgisdynamicmapservicelayer.htm#
dojo.require("esri.layers.agsdynamic"); // dynamic map services generate images on the fly.
dojo.require("esri.layers.agstiled"); // cached map service.
// esri.Map class created a container and required DOM structure for adding
// -layers, graphics, info_window, and other navigation controls
dojo.require("esri.map");
dojo.require("esri.toolbars.navigation");
dojo.require("esri.toolbars.draw");
// ESRI dojo tasks
//  esri.tasks.geometry class represents a geometry service exposed by the ArcGIS REST API.
// Operations include - project, simplify, buffer, and relationships
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/geometry.htm#
dojo.require("esri.tasks.geometry");
// Represents a geocode service resource exposed by the ArcGIS REST API.
// It is used to generate candidates for an address.
// It is also used to find an address for a given location.
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/locator.htm#
dojo.require("esri.tasks.locator");
// ESRI dojo task for querying against the ArcGIS REST API.
// Reference: http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/querytask.htm#
dojo.require("esri.tasks.query");
// ESRI dojo task for identifying against the ArcGIS REST API.
dojo.require("esri.tasks.identify");
// ESRI dojo graphics utility for displaying features in a single layer using the ArcGIS REST API.
// Reference:http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/featurelayer.htm#
dojo.require("esri.layers.FeatureLayer");
ESRI Dojo Objects End
//              SET UP DOJO END
//              DECLARE AND SET VARIABLES END
//          MAP EXTENTS
Set the extent of one map service.
For multiple map services, see the section titled Setting the beginning extent
when using multiple services at-
http://resources.esri.com/help/9.3/arcgisserver/apis/javascript/arcgis/help/jshelp_start.htm
////WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING/////////
//      WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING WARNING
//          ENSURE YOU HAVE A GEOMETRY SERVICE CREATED AND RUNNING ON
//          ESRI ArcGIS Server OR YOUR MAP MAY NOT DISPLAY
//          NOTE:   You do not necessarily need to reference the geometry service
//                  in your code.
// Extent and Spatial reference of our map service
//var startExtent = new esri.geometry.Extent({ "xmin": 778733.96207758, "ymin": 1133387.86320644, "xmax": 849794.792685476, "ymax": 1193607.08672764, "spatialReference": { "wkid": 102100} });
// This is the required projection to display in Decatur for imagery
var startExtent = new esri.geometry.Extent({ "xmin": -9907408.2369, "ymin": 4839236.5572, "xmax": -9897146.5658, "ymax": 4847826.1683, "spatialReference": { "wkid": 102100} });
// Sets the extent for the find address query
var addressExtent, newExtent;
// Map Services Begin
// Define Map Section
var gisUrl; // GIS Server Location
// Old Url - http://64.107.106.57/
gisUrl = "http://decgis01/";
var rasSvc; // Raster Service
rasSvc = "Public/Aerial_2012/MapServer";
var mapSvc; // Map Service
mapSvc = "Internal/SOA/MapServer";
var addrLocSvc; // Address Locator Service
addrLocSvc = "Public/WebAddressLocator/GeocodeServer";
var geomSvc; // Geometry Service
geomSvc = "Utilities/Geometry/GeometryServer";
var map, dynamicMapServiceLayer, imageDynamicMapServiceLayer;
dynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer(gisUrl + "arcgis/rest/services/" + mapSvc);
dynamicMapServiceLayer.setOpacity(0.4);
//imageDynamicMapServiceLayer = new esri.layers.ArcGISDynamicMapServiceLayer(gisUrl + "arcgis/rest/services/" + rasSvc);
imageDynamicMapServiceLayer = new esri.layers.ArcGISTiledMapServiceLayer("http://services.arcgisonline.com/ArcGIS/rest/services/World_Imagery/MapServer");
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/arcgisdynamicmapservicelayer.htm#setIm...
//imageDynamicMapServiceLayer.setImageFormat("jpg");
// Navigation Tools
var navToolbar;
// Locator service to be used for find address
var locator;
locator = new esri.tasks.Locator(gisUrl + "arcgis/rest/services/" + addrLocSvc);
// SR required for Decatur
var spatialReference = new esri.SpatialReference({ wkid: 102100 });
locator.setOutSpatialReference(spatialReference);
// Geometry Service
var geometryService;
geometryService = new esri.tasks.GeometryService(gisUrl + "arcgis/rest/services/" + geomSvc);
// Map Services End
// ESRI Tasks Begin
// Define Macon County Tax Parcels as Layer to Query
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jshelp/intro_querytask.htm#
var queryTask = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/6");
// Creates a new query to be used against the current geometry
var queryParams = new esri.tasks.Query();
var circleSymbol = new esri.symbol.SimpleMarkerSymbol();
circleSymbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
circleSymbol.setColor(new dojo.Color([153, 0, 51, 0.75]));
// Declare coordinate for drawing point in find address
var x1, y1;
// Declare geometry for find address
var geom;
// Identify Task
var identifyHandle;
var identifyTask, identifyParams;
// Measure Polyline
var measureLine;
var lineLengthParams = new esri.tasks.LengthsParameters();
var measureLineGraphic;
// Measure Polygon
var measurePolygon;
var polygonLengthParams = new esri.tasks.AreasAndLengthsParameters();
var measurePolygonGraphic;
// Project Point
var pt = null;
var point;
var ptSymbol;
var ptGraphic;
var ptOutSR;
var pointHandle;
var inTown;
// ESRI Tasks End
// Query Layers Begin
// Layers to evaluate if they are in a safe zone based on a sex offender's potential address
var qryBikePaths = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/1")
var qryHomeDayCare = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/2");
var qryDayCare = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/3");
var qryParks = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/4");
var qrySchools = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/5");
var qryDecaturBoundary = new esri.tasks.QueryTask(gisUrl + "arcgis/rest/services/" + mapSvc + "/7");
// Query Layers End
// Graphics Definition Begin
/* Define initial address point to be drawn for find address */
var firstGraphic;
/* Define queried point to be drawn for find address */
var graphicPt;
/* Defines the line drawn for the polygon of the parcel */
var selectParcel;
// Graphics Definition End
//          PAGE INITIALIZATION
function init() {
    // Initialize JavaScript Framework Controls
    // Round Sidebar Corners
    roundSidebarCorners();
    // Add Sidebar
    addSideBar();
    // Add Sidebar Title
    addSideBarTitle();
    // Add Map Navigation Title
    addMapNavigationTitle();
    // Add Map Navigation Content
    addMapNavigationContent();
    // Add Map Tools Title
    addMapToolsTitle();
    // Add Map Tools Content
    addMapToolsContent();
    // Add Address Search Title
    addAddressQueryTitle();
    // Add Address Search Content
    addAddressQueryContent();
    $("sideBarTop").style.cursor = "hand"; // Sidebar Top - To Drag the Sidebar
    $("sideBarTopFill").style.cursor = "hand"; // Sidebar Top Fill - To Drag the Sidebar
    $("sideBarBottom").style.cursor = "hand"; // Sidebar Bottom - To Drag the Sidebar
    $("sideBarBottomFill").style.cursor = "hand"; // Sidebar Bottom Fill - To Drag the Sidebar
    $("dojoGrid").style.display = 'none';
    $("btnClearGraphics").style.display = 'none';
    // Add Footer Section
    addFooterSection();
    addFooter();
    // Enable Sidebar Drag
    EnableDrag();
    // Set Browser to Full Size
    maxBrowserWindow();
    The proxy section is defined on the ESRI sample. I have included it as
    part of the documentation reads that the measuring will not work.
    I thought that might be important.
    // Proxy Definition Begin
    //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
    //If this null or not available the project and lengths operation will not work.  Otherwise it will do a http post to the proxy.
    esriConfig.defaults.io.proxyUrl = "proxy.ashx";
    esriConfig.defaults.io.alwaysUseProxy = false;
    // Proxy Definition End
    // Programmatically define web services
    // Add controls to the interface
    esriConfig.defaults.map.sliderLabel = null;
    //   Note:
    //          The last layer added to the map is the top layer.
    //          Setting the opacity as shown below allows for hidden
    //          layers to become visible.
    //          LAYERS
    /* Add a dynamic layer */
    All map services use a unique reference to identify the map service
    In ESRI ArcGIS Server, the unique reference is the URL of the published
    map service
    map = new esri.Map("mapSection", { extent: startExtent });
    // Enable identify
    dojo.connect(map, "onLoad", initFunctionality);
    // The dynamic layer is added to the map
    map.addLayer(imageDynamicMapServiceLayer);
    map.addLayer(dynamicMapServiceLayer);
    //alert(dynamicMapServiceLayer.layerInfos[5].name);
    //alert((dynamicMapServiceLayer.visibleLayers.length) + 1);
    // Add toolbar
    navToolbar = new esri.toolbars.Navigation(map);
    // Sets the navigation bar up to handle previous and next extent
    dojo.connect(navToolbar, "onExtentHistoryChange", extentHistoryChangeHandler);
    // Reference - http://forums.arcgis.com/threads/48318-Set-zoomToFullExtent-to-be-my-Initial-Extent
    navToolbar.zoomToFullExtent = function () {
        map.setExtent(startExtent);
    // Add Polygon Tool
    measurePolygon = new esri.toolbars.Draw(map);
    dojo.connect(measurePolygon, "onDrawEnd", function (geometry) {
        removePolygon();
        deactivatePoint();
        // This line of code is a guess
        polygonLengthParams.polygons = [geometry];
        polygonLengthParams.areaUnit = esri.tasks.GeometryService.UNIT_SQUARE_FEET;
        polygonLengthParams.areaUnit = esri.tasks.GeometryService.UNIT_ACRES;
        geometryService.simplify([geometry], function (simplifiedGeometries) {
            polygonLengthParams.polygons = simplifiedGeometries;
            geometryService.areasAndLengths(polygonLengthParams);
        geometryService.lengths(polygonLengthParams);
        measurePolygonGraphic = map.graphics.add(new esri.Graphic(geometry, new esri.symbol.SimpleFillSymbol()));
    // Add Line Tool
    measureLine = new esri.toolbars.Draw(map);
    dojo.connect(measureLine, "onDrawEnd", function (geometry) {
        deactivatePoint();
        removePolygon();
        lineLengthParams.polylines = [geometry];
        lineLengthParams.lengthUnit = esri.tasks.GeometryService.UNIT_FOOT;
        lineLengthParams.geodisc = true;
        geometryService.lengths(lineLengthParams);
        measureLineGraphic = map.graphics.add(new esri.Graphic(geometry, new esri.symbol.SimpleLineSymbol()));
    // Diplay Polygon Area and Distance after measuring
    dojo.connect(geometryService, "onAreasAndLengthsComplete", outputAreaAndLength);
    // Display Line Distance after measuring
    dojo.connect(geometryService, "onLengthsComplete", outputDistance);
    // Make Address Locator Available
    dojo.connect(locator, "onAddressToLocationsComplete", showResults);
    // Connect the row click item to the dojo grid
    dojo.connect(dojoGrid, "onRowClick", onRowClickHandler);
    // Enable tab display for identify
    dojo.connect(map.infoWindow, "onShow", function () {
        dijit.byId("tabs").resize();
Map Tools Begin
// Add history reference for previous and next extent on map toolbar
function extentHistoryChangeHandler() {
    $("btnPrevExtent").disabled = navToolbar.isFirstExtent();
    $("btnNextExtent").disabled = navToolbar.isLastExtent();
Find Address Point Function Begins
function findAddress() {
    if (Page_IsValid) {
        // Clear the map
        map.graphics.clear();
        $("lblResponse").innerHTML = "";
        $("lblAddressStatus").innerHTML = "";
        var add = dojo.byId("txtAddress").value.split(",");
        var address = {
            SingleKey: add[0]
        Locator begins searching for address matches when the method addressToLocations is called.
        The event listener onAddressToLocationsComplete calls the function showResults()
        onAddressToLocationsComplete fires when Locator.addressToLocation() has completed
        locator.addressToLocations(address);
function showResults(candidates) {
    var candidate;
    var symbol = new esri.symbol.SimpleMarkerSymbol();
    var infoTemplate = new esri.InfoTemplate("Location", "Address: ${address}<br />Score: ${score}");
    symbol.setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
    symbol.setColor(new dojo.Color([255, 0, 0, 0.75]));
    var points = new esri.geometry.Multipoint(map.spatialReference);
    var incrementor = 0;
    var validRecords = 0;
    var xLoc, yLoc, singleAddress;
    $("dojoGrid").style.display = 'inherit';
    var items = [], obj = {}, loc;
    dojo.forEach(candidates,
  function (candidate) {
     if (candidate.score > 50) {
         obj = {};
         obj['address'] = candidate.address;
         obj['score'] = candidate.score;
         loc = candidate.location;
         obj['x'] = loc.x;
         obj['y'] = loc.y;
         obj['location'] = loc.x + ', ' + loc.y;
         items.push(obj);
    console.log(items);
    // Create data object to be used in store
    var data = {
        items: items
    // Create data store and bind to grid
    store = new dojo.data.ItemFileReadStore({ data: data });
    var grid = new dojox.grid.DataGrid;
    grid = dijit.byId('dojoGrid');
    grid.setStore(store);
    // Evaluate number of addresses returned
    // if there is only one address, set the height of the grid to 0
    if (items.length == 1) {
        $("dojoGrid").style.height = 0
    else {
        // if there is more than one address set the height 50x the number of items addresses returned
        $("dojoGrid").style.height = 50 * items.length;
    // Evaluate if any candidates exist
    if (candidates.length == 0) {
        $("lblAddressStatus").innerHTML = "The Address you entered is not recognized. Make sure you entered it correctly.";
        $("lblAddressStatus").className = "warningMessage";
        $("lblResponse").innerHTML = " Your address should be like the example:" +
        "<br> 111 E MAIN ST " +
        "<br> And the format should be:" +
        "<br> Street Address";
        $("lblResponse").className = "warningMessage";
        $("lblBikePath").innerHTML = "";
        $("lblHomeDayCare").innerHTML = "";
        $("lblDayCare").innerHTML = "";
        $("lblParks").innerHTML = "";
        $("lblSchools").innerHTML = "";
        $("lblCityLimits").innerHTML = "";
        navToolbar.zoomToFullExtent();
        // exit code
        return;
    else {
        // Check all candidates for a matching score greater than 50
        for (incrementor; incrementor < candidates.length; incrementor++) {
            candidate = candidates[incrementor];
                var attributes = { address: candidates[incrementor].address, score: candidates[incrementor].score };
                var graphic = new esri.Graphic(candidates[incrementor].location, symbol, attributes, infoTemplate);
                map.graphics.add(graphic);
                map.graphics.add(new esri.Graphic(candidate.location, new esri.symbol.TextSymbol(attributes.address).setOffset(0, 8)));
                points.addPoint(candidate.location);
                validRecords = incrementor + 1;
                xLoc = candidates[incrementor].location.x;
                yLoc = candidates[incrementor].location.y;
                singleAddress = candidates[incrementor].address;
        if (validRecords > 1) {
            $("lblAddressStatus").innerHTML = "Success!";
            $("lblAddressStatus").className = "normalMessage";
            map.setExtent(points.getExtent().expand(3));
            $("btnClearGraphics").style.display = 'inherit';
        else if (validRecords == 0) {
        else if (validRecords == 1) {
            // Coordinates of single address returned
            $("lblAddressStatus").innerHTML = "The Address " + singleAddress + " was found.";
            map.setExtent(points.getExtent());
            x1 = xLoc;
            y1 = yLoc;
            geom = new esri.geometry.Point(x1, y1, new esri.SpatialReference({ wkid: 343 }));
            graphicPt = new esri.Graphic(geom, symbol);
            // Add Point
            map.graphics.add(graphicPt);
            // Initialize Query
            var qry = new esri.tasks.Query();
            qry.returnGeometry = true;
            qry.ourSpatialReference = { "wkid": 102100 };
            qry.geometry = geom;
            // Check if point is in city limits
            qry.spatialRelationship = esri.tasks.Query.SPATIAL_INTERSECTS;
            qryDecaturBoundary.execute(qry, qryDecaturBoundary_complete);
Display Grid Cell That Was Clicked
function onRowClickHandler(evt) {
    // Set X and Y Coordinates
    x1 = dojoGrid.getItem(evt.rowIndex).x;
    y1 = dojoGrid.getItem(evt.rowIndex).y;
    // Declare geometry and assign coordinates
    // http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/point.htm#
    // http://help.arcgis.com/en/webapi/javascript/arcgis/help/jsapi/point.htm#PointConst1
    // Required for Decatur
    geom = new esri.geometry.Point(x1[0], y1[0], new esri.SpatialReference({ wkid: 102100 }));
    graphicPt = new esri.Graphic(geom, circleSymbol);
    // Add Point
    // Initialize Query
// Custom Buffer Sample
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/util_buffergraphic.html#
// http://help.arcgis.com/en/webapi/javascript/arcgis/help/jssamples/exp_cors_buffer.html
function doBuffer(geometry) {
    // Set up buffer parameters
    var params = new esri.tasks.BufferParameters();
    params.distances = [500];
    params.bufferSpatialReference = new esri.SpatialReference({ wkid: 3435 });
    params.outSpatialReference = map.spatialReference;
    params.unit = esri.tasks.GeometryService.UNIT_FOOT;
    geometryService.simplify([geometry], function (geometries) {
        params.geometries = geometries;
        geometryService.buffer(params, showBuffer);
function showBuffer(bufferedGeometries) {
    var symbol = new esri.symbol.SimpleFillSymbol(
                esri.symbol.SimpleFillSymbol.STYLE_SOLID,
                    esri.symbol.SimpleLineSymbol.STYLE_SOLID,
                    new dojo.Color([255, 0, 0, 0.65]), 2
                new dojo.Color([255, 0, 0, 0.35])
    var graphic;
    dojo.forEach(bufferedGeometries, function (geometry) {
        graphic = new esri.Graphic(geometry, symbol, { buffer: true });
        // Add point
        // Add polygon
        map.graphics.add(firstGraphic);
        // Add Buffer
    map.setExtent(bufferedGeometries[0].getExtent().expand(2));
    // evaluate if buffered geometries intersect with safe zones
    queryParams.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
    queryParams.returnGeometry = true;
    queryParams.geometry = graphic.geometry;
    // Evaluate if buffer intersects with bikepaths
    qryBikePaths.execute(queryParams, qryBikePaths_complete);
    // Evaluate if buffer intersects with a daycare
    qryDayCare.execute(queryParams, qryDayCare_complete);
    // Evaluate if buffer intersects with playground equipment
    qryParks.execute(queryParams, qryParks_complete);
    // Evaluate if buffer intersects with a Home Daycare
    qryHomeDayCare.execute(queryParams, qryHomeDayCare_complete);
    // Evaluate if buffer intersects with a school
    qrySchools.execute(queryParams, qrySchools_complete);
// Evaluate if address is in City Limits
function qryDecaturBoundary_complete(featureSets) {
    if (featureSets.features.length > 0) {
        // Initialize Query
        var query = new esri.tasks.Query();
        query.returnGeometry = true;
        // This SR is requirer to draw the parcel polygon
        query.outSpatialReference = { "wkid": 102100 };
        query.geometry = geom;
        // Checks where point intersects with parcel
        query.spatialRelationship = esri.tasks.Query.SPATIAL_REL_INTERSECTS;
        queryTask.execute(query);
        // Declare the graphic for the polygon
        firstGraphic = null;
        selectParcel = null;
        // +++++Listen for QueryTask onComplete event+++++
        dojo.connect(queryTask, "onComplete", function (graphics) {
            firstGraphic = graphics.features[0];
            selectParcel = new esri.symbol.SimpleFillSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new esri.symbol.SimpleLineSymbol(esri.symbol.SimpleFillSymbol.STYLE_SOLID, new dojo.Color([98, 194, 204]), 3), new dojo.Color([255, 0, 0, 0]));
            firstGraphic.setSymbol(selectParcel);
            // Add Polygon Graphic On parcel as Selection
            geometry = graphics.features[0].geometry;
            // Buffer polygon
            doBuffer(geometry);
    else {
        $("lblResponse").innerHTML = "It's outside the city.";
    return inTown;
// Evaluate Safe Zones
function qryBikePaths_complete(featureSet) {
    if (featureSet.features.length > 0) {
        $("lblBikePath").innerHTML = "Caution, Bikepath";
        $("lblBikePath").className = "cautionMessage";
    else {
        $("lblBikePath").innerHTML = "Bikepath Safe";
        $("lblBikePath").className = "successMessage";
function qryHomeDayCare_complete(featureSet) {
        $("lblHomeDayCare").innerHTML = "Home Daycare Unsafe";
        $("lblHomeDayCare").className = "warningMessage";
    else {
        $("lblHomeDayCare").innerHTML = "Home Daycare Safe";
        $("lblHomeDayCare").className = "successMessage";
function qryDayCare_complete(featureSet) {
        $("lblDayCare").innerHTML = "Daycare Unsafe";
        $("lblDayCare").className = "warningMessage";
    else {
        $("lblDayCare").innerHTML = "Daycare Safe";
        $("lblDayCare").className = "successMessage";
function qryParks_complete(featureSet) {
        $("lblParks").innerHTML = "Parks Unsafe";
        $("lblParks").className = "warningMessage";
    else {
        $("lblParks").innerHTML = "Parks Safe";
        $("lblParks").className = "successMessage";
function qrySchools_complete(featureSet) {
        $("lblSchools").innerHTML = "Schools Unsafe";
        $("lblSchools").className = "warningMessage";
    else {
        $("lblSchools").innerHTML = "Schools Safe";
        $("lblSchools").className = "successMessage";
function clearResults() {
    $("txtAddress").value = "111 MAIN ST";
function initFunctionality(map) {
    identifyTask = new esri.tasks.IdentifyTask(gisUrl + "arcgis/rest/services/" + mapSvc);
    identifyParams = new esri.tasks.IdentifyParameters();
    identifyParams.tolerance = 3;
    identifyParams.returnGeometry = true;
    identifyParams.layerIds = [0, 1, 2, 3, 4, 5, 6];
    identifyParams.layerOption = esri.tasks.IdentifyParameters.LAYER_OPTION_ALL;
    identifyParams.width = map.width;
    identifyParams.height = map.height;
    map.infoWindow.resize(415, 200);
    map.infoWindow.setContent(dijit.byId("tabs").domNode);
    map.infoWindow.setTitle("Identify Results");
function doIdentify(evt) {
    identifyParams.geometry = evt.mapPoint;
    identifyParams.mapExtent = map.extent;
    identifyTask.execute(identifyParams, function (idResults) { addToMap(idResults, evt); });
function addToMap(idResults, evt) {
    addressResults = { displayFieldName: null, features: [] }; // 0
    inHomeDayCareResults = { displayFieldName: null, features: [] }; //2
    dayCareFacilitiesResults = { displayFieldName: null, features: [] }; //3
    playgroundResults = { displayFieldName: null, features: [] }; //4
    schoolPropertyResults = { displayFieldName: null, features: [] }; //5
    maconTaxParcelResults = { displayFieldName: null, features: [] }; // 6
    // evaluate for layers 0,1, 3, 4, 5, and 6
    for (var i = 0, il = idResults.length; i < il; i++) {
        var idResult = idResults;
        if (idResult.layerId === 0) {
            if (!addressResults.displayFieldName) { addressResults.displayFieldName = idResult.displayFieldName };
            addressResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(addressResults, "addressResults"));
            i = idResults.length + 1;
        else if (idResult.layerId === 2) {
            if (!inHomeDayCareResults.displayFieldName) { inHomeDayCareResults.displayFieldName = idResult.displayFieldName };
            inHomeDayCareResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(inHomeDayCareResults, "inHomeDayCareResults"));
        else if (idResult.layerId === 3) {
            if (!dayCareFacilitiesResults.displayFieldName) { dayCareFacilitiesResults.displayFieldName = idResult.displayFieldName };
            dayCareFacilitiesResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(dayCareFacilitiesResults, "dayCareFacilitiesResults"));
        else if (idResult.layerId === 4) {
            if (!playgroundResults.displayFieldName) { playgroundResults.displayFieldName = idResult.displayFieldName };
            playgroundResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(playgroundResults, "playgroundResults"));
        else if (idResult.layerId === 5) {
            if (!schoolPropertyResults.displayFieldName) { schoolPropertyResults.displayFieldName = idResult.displayFieldName };
            schoolPropertyResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(schoolPropertyResults, "schoolPropertyResults"));
        else if (idResult.layerId === 6) {
            if (!maconTaxParcelResults.displayFieldName) { maconTaxParcelResults.displayFieldName = idResult.displayFieldName };
            maconTaxParcelResults.features.push(idResult.feature);
            dijit.byId("safeZoneTab").setContent(layerTabContent(maconTaxParcelResults, "maconTaxParcelResults"));
        map.infoWindow.show(evt.screenPoint, map.getInfoWindowAnchor(evt.screenPoint));
function layerTabContent(layerResults, layerName) {
    var content = "";
    switch (layerName) {
        case "addressResults":
            content = "<i>Total features returned: " + layerResults.features.length + "</i>";
            content += "<table border='1'><tr><th>Address</th><th>PIN</th></tr>";
            for (var i = 0, il = layerResults.features.length; i < il; i++) {
                content += "<tr><td>" + layerResults.features.attributes['ADDRESS'] + " </td>";
                content += "<td>" + layerResults.features.attributes['PIN_NUM'] + "</td>";
            content += "</tr></table>";
            break;
        case "inHomeDayCareResults":
            content += "<table border='1'><tr><th>Description</th><th>Address</th></tr>";
                content += "<tr><td>" + layerResults.features.attributes['USAGE_DESC'] + " </td>";
                content += "<td>" + layerResults.features.attributes['ADDRESS'] + "</td>";
            break;
        case "dayCareFacilitiesResults":
            content += "<table border='1'><tr><th>Description</th><th>Name</th></tr>";
                content += "<tr><td>Daycare Facilities</td>";
                content += "<td>" + layerResults.features.attributes['SCHOOL_NAM'] + "</td>";
            break;
        case "playgroundResults":
                content += "<tr><td>Playgrounds</td>";
                content += "<td>" + layerResults.features.attributes['PARKNAME'] + " </td>";
            break;
        case "schoolPropertyResults":
                content += "<tr><td>School Property</td>";
            break;
        case "maconTaxParcelResults":
            content += "<table border='1'><tr><th>Name</th><th>Address</th></tr>";
                content += "<tr><td>" + layerResults.features.attributes['PRIMARYNAME'] + " </td>";
                content += "<td>" + layerResults.features.attributes['SITEADDRESS'] + " </td>";
            content += "</tr></table";
            break;
    return content;
function runIdentify() {
    measureLine.deactivate();
    removePolygon();
    removePolyline();
    measurePolygon.deactivate();
    identifyHandle = dojo.connect(map, "onClick", doIdentify);
    identifyHandle;
function outputDistance(result) {
    dojo.byId("lblDistance").innerHTML = "  " + dojo.number.format(result.lengths[0]) + " feet";
function outputAreaAndLength(result) {
    console.log(dojo.toJson(result));
    dojo.byId("lblDistance").innerHTML = "  " + dojo.number.format(result.areas[0]) + " sq. feet";
function removePolyline() {
    // Remove line graphics
    map.graphics.remove(measureLineGraphic);
    // Deactivate measure line
    // Remove point
    map.graphics.remove(ptGraphic);
    // Deactivate pointhttp://maps.decaturil.gov/ArcGIS/rest/services/InternalMapSampleServiceTest/MapServer/2 or the current URL
    dojo.disconnect(pointHandle);
function removeMeasureTools() {
    // Remove point
    // Deactivate point
    // Remove polygon
    map.graphics.remove(measurePolygonGraphic);
    // Deactivate polygon
// Deactivates Navtoolbar and Identify
function deactivateNavToolbar() {
    // Deactivate Toolbar
    navToolbar.deactivate();
    // Deactivate Identify
    dojo.disconnect(identifyHandle);
// Deactivates Identify
function deactivateIdentify() {
    // Disables identify
function projectPoint() {
    // Remove the line graphics
    // Remove polygon graphics
    // Deactivate the nav toolbar
    // Deactivate identify
    deactivateIdentify();
    // Wire up the point handle to run the projectToWebMercator
    pointHandle = dojo.connect(map, "onClick", projectToWebMercator);
    pointHandle;
function projectToWebMercator(evt) {
    point = evt.mapPoint;
    ptSymbol = new esri.symbol.SimpleMarkerSymbol().setStyle(esri.symbol.SimpleMarkerSymbol.STYLE_CIRCLE);
    ptGraphic = new esri.Graphic(point, ptSymbol);
    ptOutSR = new esri.SpatialReference({ wkid: 102100 });
    map.graphics.add(ptGraphic);
    geometryService.project([point], ptOutSR, function (projectedPoints) {
        point = projectedPoints[0];
        dojo.byId("lblDistance").innerHTML = "  x:" + dojo.number.format(point.x) + ", y:" + dojo.number.format(point.y);
    // Disconnect point handle
function clearPointAndPolygon() {
    removePoint();
    removePolygon();
function clearPointAndLine() {
    removePoint();
    removePolyline();
function removePoint() {
function removePolygon() {
function deactivatePoint() {
function printMap() {
    alert("Print Map");
function getHelp() {
    alert("Help Me");
Map Tools End
// Rico Functions
function roundSidebarCorners() {
    roundCorners('sideBarTop',
                        corners: "top",
                        color: "#E1EBFB"
    roundCorners('sideBarBottom',
                        corners: "bottom",
                        color: "#E1EBFB"
// Dojo Function
// Add Sidebar
function addSideBar() {
    var sideBarConfig = new dijit.layout.BorderContainer({
        $("sideBar")
function addSideBarTitle() {
    var sideBarTitleConfig = new dijit.TitlePane({
        title: "SOA Tools"
        $("sideBarTitle")
// Add Map Navigation title
function addMapNavigationTitle() {
    var mapNavigationTitleConfig = new dijit.TitlePane({
        title: "Navigation", open: true
            $("mapNavigationTitle")
function addMapNavigationContent() {
    var mapNavigationContentConfig = new dijit.layout.ContentPane({
        $("mapNavigationContent")
function addMapToolsTitle() {
    var mapToolsTitleConfig = new dijit.TitlePane({
        title: "Map Tools", open: false
            $("mapToolsTitle")
function addMapToolsContent() {
    var mapToolsContentConfig = new dijit.layout.ContentPane({
        $("mapToolsContent")
// Add Address Query Title
function addAddressQueryTitle() {
    var addressQueryTitleConfig = new dijit.TitlePane({
        title: "Address Search", open: true
        $("queryAddressTitle")
// Add Query Address Content
function addAddressQueryContent() {
    var addressQueryContentConfig = new dijit.layout.ContentPane({
    $("queryAddress")
function addFooterSection() {
    var footerSection = new dijit.TitlePane({
        title: "Ask For Assistance", open: false
            $("footerTitle")
// Add Footer
function addFooter() {
    var pageFooter = new dijit.layout.ContentPane({
        $("footer")
// Scriptaculous Functions
function EnableDrag() {
    new Draggable($("sideBar"));
//Maximize Browser Window Begin
// Reference - http://www.javascriptfreecode.com/53.htm
function maxBrowserWindow() {
    top.window.moveTo(0, 0);
    if (document.all) {
        top.window.resizeTo(screen.availWidth, screen.availHeight);
    else if (document.layers || document.getElementById) {
        if (top.window.outerHeight < screen.availHeight || top.window.outerWidth < screen.availWidth) {
            top.window.outerHeight = screen.availHeight;
            top.window.outerWidth = screen.availWidth;
// Maximize Browser Window End
// Initialize Page
dojo.addOnLoad(init);@
DeniseDemone
I just had a similar issue, but it was the buffer that needed to be modified, not the measurement. By default the buffer uses an euclidean distance and the measure uses geodesic. If you're using ArcGIS Server 10.1 or above, the Buffer service has been updated to include a flag to enable geodesic calculations: bufferParamaters.geodesic = true
Geodesic buffering | ArcGIS API for JavaScript
Hope this helps!
