Hi everyone,
I am using this example for creating the buffer and passing the geometry into feature layer by using applyedits function.
Now, I want to use editing widget tool but not need to change or add the vertices to that draw feature. By passing the geometry to the featurelayer.applyedits function I cannot control on the geometry. Which say i can move the draw geometry into any direction. I need some help for how to achieve this.
Thanks for the help.
Sai,
Here is the sample updated to use AMD style and adding mouse over editing to the buffers.
<!DOCTYPE html>
<html>
<head>
<meta http-equiv="Content-Type" content="text/html; charset=utf-8">
<meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no">
<title>Buffer</title>
<link rel="stylesheet" href="https://js.arcgis.com/3.20/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="https://js.arcgis.com/3.20/esri/css/esri.css">
<script src="https://js.arcgis.com/3.20/"></script>
<script>
var map = null,
gsvc = null,
clickHandler = null,
editingEnabled = false,
bufferGL = null;
require([
"esri/map",
"esri/toolbars/edit",
"esri/graphic",
"esri/Color",
"esri/symbols/SimpleMarkerSymbol",
"esri/symbols/SimpleLineSymbol",
"esri/symbols/SimpleFillSymbol",
"dojo/_base/array",
"dojo/_base/lang",
"dojo/on",
"esri/tasks/GeometryService",
"esri/tasks/BufferParameters",
"esri/layers/GraphicsLayer",
"dojo/domReady!"
], function(
Map, Edit, Graphic, Color,
SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
arrayUtils, lang, on, GeometryService, BufferParameters, GraphicsLayer
map = new Map("map", {
basemap: "streets",
center: [-96.935, 32.872],
zoom: 9
var editToolbar = new Edit(map);
gsvc = new GeometryService("https://utility.arcgisonline.com/ArcGIS/rest/services/Geometry/GeometryServer");
clickHandler = on.pausable(map, "click", doBuffer);
bufferGL = new GraphicsLayer({opacity: 0.7});
map.addLayer(bufferGL);
bufferGL.on("mouse-over", function(evt){
clickHandler.pause();
if (editingEnabled === false) {
editingEnabled = true;
editToolbar.activate(Edit.MOVE , evt.graphic);
} else {
editToolbar.deactivate();
editingEnabled = false;
bufferGL.on("mouse-out", function(evt){
clickHandler.resume();
function doBuffer(evt) {
map.graphics.clear();
var params = new BufferParameters();
params.geometries = [evt.mapPoint];
//buffer in linear units such as meters, km, miles etc.
params.distances = [10];
params.unit = GeometryService.UNIT_KILOMETER;
params.outSpatialReference = map.spatialReference;
gsvc.buffer(params, showBuffer);
function showBuffer(geometries) {
var symbol = new SimpleFillSymbol(
SimpleFillSymbol.STYLE_SOLID,
new SimpleLineSymbol(
SimpleLineSymbol.STYLE_SOLID,
new Color([0, 0, 255, 0.65]), 2
new Color([0, 0, 255, 0.35])
arrayUtils.forEach(geometries, function(geometry) {
var graphic = new Graphic(geometry, symbol);
bufferGL.add(graphic);
</script>
</head>
<body class="claro">
<b>Click a location on the map to buffer. Click again on another location to buffer again.</b>
<div id="map" style="width:600px; height:400px; border:1px solid #000;"></div>
</body>
</html>
Sai,
<!DOCTYPE html>
<html>
<head>
<script>
var map = null,
gsvc = null,
bufferGL = null;
require([
"esri/map",
"esri/graphic",
"esri/Color",
"dojo/_base/array",
"dojo/_base/lang",
"dojo/on",
"dojo/domReady!"
], function(
basemap: "streets",
zoom: 9
} else {
</script>
</head>
</body>
</html>
Thanks Robert.
But I want to save the Graphic in to my feature layer. How can we do this?
You just use featurelayer.applyedits and pass in your new graphic.
Thanks for help Robert.
How can added attribute data into feature layer while passing the graphic.
A graphic object has an attributes property that you set to and object (key value pairs).
Can you give an example for above property.
Thanks for the help
Sorry this is very basic stuff covered in the API docs (line 9 and 13):
Graphic | API Reference | ArcGIS API for JavaScript 3.20
require([
"esri/geometry/Point", "esri/symbols/SimpleMarkerSymbol",
"esri/Color", "esri/InfoTemplate", "esri/graphic", ...
], function(Point, SimpleMarkerSymbol, Color, InfoTemplate, Graphic, ... ) {
var pt = new Point(xloc,yloc,map.spatialReference)
var sms = new SimpleMarkerSymbol().setStyle(
SimpleMarkerSymbol.STYLE_SQUARE).setColor(
new Color([255,0,0,0.5]));
var attr = {"Xcoord":evt.mapPoint.x,"Ycoord":evt.mapPoint.y,"Plant":"Mesa Mint"};
var infoTemplate = new InfoTemplate("Vernal Pool Locations","Latitude: ${Ycoord} <br/>
Longitude: ${Xcoord} <br/>
Plant Name:${Plant}");
var graphic = new Graphic(pt,sms,attr,infoTemplate);
Is there any possible way to reset the "clickHandler.ID" value.
