ArcGIS JS Layer order
2553
08-31-2023 01:44 AM
Wade
How do I query the current layer sorting in the map and change it?
JoelBennett
MVP Regular Contributor
Aside from a couple exceptions, the order in which layers are drawn is the same as the order in which layers are found in the Map.allLayers property.  Changing the order of layers is made possible through the Map.reorder method,
As for the exceptions, see the notes in the documentation for the allLayers property and the reorder method, both of which are hyperlinked above.
