applyEdits for updating data (JS4.4)
4459
12
09-11-2017 07:13 AM
by Anonymous User
Not applicable
I am having a problem updating a feature layer data using applyEdits function.  I looked at the sample code in applyEdits API reference and Sandbox sample code, but I haven't been able to figure it out how to update the data.  I am only interested in updating existing data attributes.  I would very much appreciate your help.
require([
  "esri/Map",
  "esri/views/SceneView",
  "esri/layers/FeatureLayer",
  "esri/geometry/Extent",
  'esri/geometry/ScreenPoint',
  'dojo/_base/lang',
  "dojo/on",
  "dojo/dom",
  "dojo/domReady!"
  function (
    Map, SceneView, FeatureLayer, Extent, ScreenPoint, lang, on, dom
    var lyrUrl = 'https://services1.arcgis.com/aT1T0pU1ZdpuDk1t/arcgis/rest/services/CALO_survey_web/FeatureServer/0';
    var map = new Map({
      basemap: 'satellite'
    var initialExtent = new Extent({
      xmin: -8520399.50094139,
      xmax: -8466523.75224205,
      ymin: 4109431.55147233,
      ymax: 4173688.01969221,
      spatialReference: 102100
    var featureLyr = new FeatureLayer({
      url: lyrUrl
    map.add(featureLyr);
    var sceneView = new SceneView({
      container: 'map',
      map: map,
      extent: initialExtent
    var _onclick = function (evt) {
      var s = new ScreenPoint({
        x: evt.x,
        y: evt.y
    // Updating feature layer data
    sceneView.hitTest(s).then(picked => {
      console.log(picked);
      if (picked.results[0].graphic) {
        var editFeature = picked.results[0].graphic;
        editFeature.attributes.YearBuilt = '2000';
        console.log('after edit', editFeature);
        var edit = {
          updateFeatures: [editFeature]
        var promise = featureLyr.applyEdits(edit);
        console.log(promise);
  sceneView.on('click', _onclick);
Tags (1)
by Anonymous User
Not applicable
Hi Robert,
Thank you for the information.  Where can I change the setting?
My layer supported operations are:
ArcGIS Online "Editing" setting is:
Where can I change geometry updates option?
RobertScheitlin__GISP
Makiko,
   The first option will allow geometry and attribute updates the second option (that you have selected) only allows attribute updates.
by Anonymous User
Not applicable
Robert,
Thank you!  It is very important to know about the editing settings!!
