any success with --calcite-label-margin-bottom?
3656
9
08-22-2022 08:24 AM
coryeicher
Hello,
Has anyone been able to update the calcite variable --calcite-label-margin-bottom and have that take effect?
I have tried applying a style with this variable set to the <CalciteLabel> element, and also to a wrapping <div>, but I do not see any change with either approach. I'm trying to change the calcite label element's margin-bottom from 12. I am working in React and bringing in Calcite via esri/calcite-components-react.
CORY EICHER
www.eichcorp.com
[email protected]
BenElan
Esri Alum
Hi @coryeicher ,
It looks like you are using v0.21.0 of CCR in the repro app. The CSS variable wasn't introduced at that point. It will work in v0.27.0 or later (v0.30.0 is the latest).
The documentation site represents the latest version. If you are stuck on an older version you can use the changelog to determine when a feature was added:
https://github.com/Esri/calcite-components/blob/master/CHANGELOG.md#100-beta84-2022-07-12
You can determine which CC version is being used by a CCR version on the cli:
npm view @esri/[email protected] dependencies["@esri/calcite-components"]
ReneRubalcava
Esri Frequent Contributor
You can do it via the :root css.
:root {
    --calcite-label-margin-bottom: 100px; /*LOL*/
 That works in a sample I tried it. Might be something with how the framework is loading css too. I would define this in a global css that won't get scoped.
https://codepen.io/odoe/pen/ExEMoBg?editors=1000
coryeicher
Hi Rene,
Thanks for the tip. I tried what you recommended and that did not work on
my end. I've been able to update other calcite css variables without issue.
-Cory
CORY EICHER
www.eichcorp.com
[email protected]
ReneRubalcava
Do you have a repro app? It might be something like the calcite css loading after your variables are defined, but can't really tell without looking at something.
Ok, so I don't know. I tried this with a regular app using the npm install and calcite and can't override it. Weird, looks like the built code has the values baked in. You might need to try a specific css target or wrap it in a span or div maybe.
BenElan
Esri Alum
Here is a sample:
https://codesandbox.io/s/calcite-label-margin-bottom-elxnkc?file=/src/App.js
For future reference, Calcite also has an Esri Community which I monitor more closely than this one:
https://community.esri.com/t5/calcite-design-system-questions/bd-p/calcite-design-system-questions
coryeicher
Ben, @ReneRubalcava,
Thanks. I see that your sandbox works, but this is not working in my app. I will prepare a repro app.
-Cory
CORY EICHER
www.eichcorp.com
[email protected]
coryeicher
@BenElan Here is an app to reproduce (attached .zip). See readme.md for build/run steps
The problematic CalciteLabel wraps an address typeahead, built from a CalciteInput + CalciteDropdown.
I actually found a workaround solution for what I was trying to do, but the original issue appears to remain. Setting this calcite variable does not affect the CalciteLabel containing my address typeahead.
In the code, search this to find the bug...
// *** calcite variable not applied ***
... and search this to find/apply my workaround solution:
/** uncomment for my solution **/
-Cory
CORY EICHER
www.eichcorp.com
[email protected]
BenElan
Esri Alum
Hmm yeah I'm not sure. It's a pretty big repro app there could be a lot going on. Can you reproduce the issue in a simplified sample? If so I'd be happy to take a closer look.
BenElan
Esri Alum
Hi @coryeicher ,
coryeicher
Hi @BenElan
That was it! The variable is working for me after upgrading esri/calcite-components-react to 0.30.0, and also making sure esri/calcite-components is upgraded to 1.0.0-beta.93.
Thanks again,
-Cory
CORY EICHER
www.eichcorp.com
[email protected]
