Accessing the esri js api over https
1910
08-02-2010 06:30 AM
KevinGooss
I am building a website that will be SSL-secured as https.
I want to be able to pull in the esri js api as https.
I can change the link to get the api by adding the s to http and it works fine - the initial call for the api comes over the wire as https.
However, the api itself makes subsequent calls for content that are not https. How can I get around this issue without having to host the entire api myself?
timothysimons
hey i am also the same setup as yours? anyone who can bring light to this question?????
TIA
timothysimons
Hi KG22,
Have you found anything realted to this issue?
TIA
RebeccaMaaser
Here's info we got from ESRI when we asked about this:
A potential workaround is to update the tile urls after the layer is loaded and replace http with https, here's a code snippet that shows this.
function init() {
    var map = new esri.Map("map");
    //Creates the Virtual Earth layer to add to the map
    veTileLayer = new esri.virtualearth.VETiledLayer({
    bingMapsKey: '', //set to your key
    mapStyle: esri.virtualearth.VETiledLayer.MAP_STYLE_AERIAL
    dojo.connect(veTileLayer, "onLoad", function(){
    veTileLayer.tileServers = dojo.map(veTileLayer.tileServers, function(tileServer) {
    return tileServer.replace("http:","https:");
    map.addLayer(veTileLayer);
