ArcGIS Instant Apps Questions
90
2.4M
647
Open | Instant app is a wonderfull solution for fast en precise analysis.But the filters are not cascading. So for example I... by PatrickvanderStappen New Contributor II 2 1 | 2 | 1 | |
Open | Hi all,Currently when exporting a Zone Lookup to PDF it gives you a somewhat disjointed looking PDF and it would be g... by PanjiBrotoisworoIntrax New Contributor II 0 0 | 0 | 0 | |
Open | I made an instant app with attachement viewer for users to see the details from geotagged images in road projects whe... by Jarl-EirikVaadal New Contributor II 3 1 | 3 | 1 | |
Open | Idea: Don't automatically change the map extent when a new layer is selected in the Attachment Viewer Instant App (or... by HollyTorpey_LSA Occasional Contributor III 0 0 | 0 | 0 | |
Open | I just created my first Chart Viewer Instant App, which involved 3 different data layers. What I really wanted was t... by sblake_everettwa New Contributor II 0 0 | 0 | 0 | |
Open | I found out the other day that both these templates don't have the option to enable the legend on the map.It would re... by Ed_ ![]() 0 2 | 0 | 2 | |
Open | There are functionality issues with selecting a value from a drop down menu when editing data using an iOS in Instant... by TheaEvans New Contributor II 1 0 | 1 | 0 | |
Open | It would be nice if we had the choice to hide the toolbar if we only have one widget in the Sidebar Instant App. I'm ... by ChelseaRozek ![]() 1 3 | 1 | 3 | |
Open | I would appreciate it if in Atlas Instant App will be option to sort layers and maps, which I can add to map. For e... by AnnaHradecká New Contributor III 3 0 | 3 | 0 | |
Open | It would be great if there was increase the export/print options when configuring Export in the Sidebar Instant appPo... by RyanBohan Regular Contributor 3 4 | 3 | 4 | |
Open | Hi, I'm currently in the process of trying to pull together a 'site checker' which will enable the users to select a ... by James_Shreeve New Contributor III 0 6 | 0 | 6 | |
Open | In the Media Map instant app, the setting for "Enable hover pop-up" is currently located under About --> Location det... by PeterKnoop ![]() 0 2 | 0 | 2 | |
Open | Hi, Simple idea, which I believe can be implemented in Experience Builder Could it be possible to change the eye icon... by James_Shreeve New Contributor III 0 2 | 0 | 2 | |
Open | Unlike other areas of AGO, you can't filter by group when adding content to an instant app. Once you select My Groups... by wayfaringrob Frequent Contributor II 1 0 | 1 | 0 | |
Open | Atlas is great Instant App template, but I have recommendations for Map Layer list:1) Show options (transparency, swi... by AnnaHradecká New Contributor III 4 0 | 4 | 0 |
Idea Submission Guidelines
User | Count |
1 | |
1 | |
1 | |
1 |
