Error when i try to reserver a hotel or Roome un Indoors Viewer
2166
10
02-09-2023 01:03 PM
SimonMarin
Hi, everyone.
I'm working whit ArcGIS Indoors set up the Indoor viewer using data referenced and branch versioning.
at this moment the web app shows me the units that I can reserve, but when I click to make the reserve, I get back an error.
I'm using ArcGIS Enterprise Version 10.9.1 whit a DataBase PostgreSQL
If any knows why or if there is something that I could do to overcome this issue
i will be thankful
Simon Marin
Solution engineer- Esri Colombia
SimonMarin
Hi everyone.
First thanks for all your post, these were constructive.
I could solve this issue :D.
for this solution, I publish the reservation layer as copy data in the ArcGIS portal instead of as referenced data to the enterprise database.
This solution works in ArcGIS Enterprise 10.9.1
Simon Marin
Tags (1)
GauravJobanputra
Hello @SimonMarin only Occupants and Units are supposed to be branched versioned. There is no versioning needed for Reservations. Can you please check your feature service and confirm?
SimonMarin
Hi @GauravJobanputra .
The reservation's layer has the branch versioning activated, but I can't disable it, because it is in the indoors dataset where are the units and occupants layers.
So please tell me if I could delete the layer reservation and create it again outside the indoor dataset.
Thanks
Simon Marin
GauravJobanputra
Hello @SimonMarin, please go through the following topics to get the desired web map configuration and avoid the error you are encountering.
  1. Create a Space Planner web map
  2. Share a Space Planner web map to Enterprise
  3. Configure using the Reservations layer in Indoors
After this you should not see any issues. I am assuming you are on the latest version of ArcGIS Enterprise (v11.0). If not, then please let me know what version.
GauravJobanputra
Hi @SimonMarin, were you able to get the Reservation layer shared separately and get this to work? Even if the dataset is registered as versioned you can select not to enable version management when sharing as a web layer.
Leo_GTRI
feature dataset items cannot be individually set for non branched versioning.  What is the workflow here?
GauravJobanputra
@Leo_GTRI version management can be enabled selectively when sharing as a web layer even if the dataset is registered as branch versioned. Space Planner requires only Occupants and Units to have version management. Reservation layer is only used in Indoor Viewer and should not be shared with version management enabled.
Follow steps in this topic to for enabling version management.
SimonMarin
Hi everyone.
Simon Marin
Tags (1)
Leo_GTRI
I did the same thing, but the documentation clearly states you should be able to share as referenced data in Enterprise.
To gain added security provided by the constraint attribute rule, the Reservations layer must be   that references registered data. Otherwise, the Reservations layer is published without the attribute rule. Attribute rules are not available in hosted feature layers in ArcGIS Enterprise or ArcGIS Online.
SimonMarin
Yes, @Leo_GTRI.
I think that documentation is for ArcGIS Enterprise 11.0 and my deployment is over the 10.9.1 version.
Simon Marin
