Where to Find IDs and Classes
3865
07-22-2014 02:28 PM
JonathanFarmer1
I am working on customizing our Open Data Portal using the "Code" tabs on the site setup page. For the life of me, I can't seem to find the standard Div IDs and Classes that ESRI used to build this site?
At the moment I am looking at the Vaccination Tracking System Open Data Portal in Google Chrome Developer Tools to find what I need which works but is cumbersome. Is there a list somewhere I'm missing that ESRI has put out for developers?
In case anyone is curious what I am talking about, I'll give an example. The green bar located below the header on the Vaccination site has a Div ID of "title-wrap". I only know this because of Google's Dev Tools but surely there is a listing of existing IDs and Classes out there?
Thanks for the help!
-Jonathan
by Anonymous User
Not applicable
Hi Jonathan,
We will be adding a topic for this to the help soon, and even working on a better experience for the site designer. In the mean time, check out this document for help.
Hope that helps,
Andrew
by Anonymous User
Not applicable
Hi Jonathan,
Hope that helps,
Andrew
JonathanFarmer1
Thanks Andrew, that would be great! In the meantime, this document will help with most of the things I need and I will use the Dev Tools to find the rest.
So far though, it has been pretty painless to customize just about every aspect of the site design.
-Jonathan
