Issues Created in Autodesk Construction Cloud Not Georeferencing Correctly
1541
04-24-2022 07:24 AM
Jeremy_M
I'm trying to sync the issues created in Autodesk Construction Cloud to be shown in ArcGIS GeoBIM. I have run the ArcGIS GeoBIM tools to find issues and boundaries for my documents in ACC. The .rvt models appear to be referenced in the correct place as a .prj file has been placed along with the model in the ACC folder. However, the issues that are created within ACC on those .rvt models keep showing up in a different place that is not even within the document boundary.
Did I miss a step somewhere?
Thank you in advance for your help.
Jeremy
StephenBrockwell
Hello Jeremy. Thanks for your question. At the moment, Autodesk is replacing the ACC issues API. Our next release will integrate the new API and support both BIM360 and ACC. However, for issues, that work is not complete at this time. We will be posting a release note on it in the next two weeks.
StephenBrockwell
