Unable to select the "Size & Color" map theme
1183
12-12-2017 04:39 AM
DominicEve
We are experiencing an issue with the latest version of ARCGIS maps for Power BI (downloaded via the Microsoft Store) where we specify a color value and a size value, however when we select the map theme the "Size & Color" map theme can't be selected (it's visible but can't be clicked). The desired outcome is that when this is selected, we can select the "Symbol Style" and be able to set the individual colors for each category value returned - which was functionality that worked with this same dataset and visualisation in an earlier version.
The value for the color is a calculated measure that returns a text value, however we have also tested with a standard category field without success.
AdrianSánchez_Rodríguez
Hello,
I'm having the same issue as described in this post (a few years later though).
Size and color theme was working just fine but now I suddenly lost all settings.
I am able to set up the format on the Edit view, but once I hit on "Go back to report", the visual shows the by-default green-blue color. It seems to keep the Size formatting.
When choosing the Color theme, it seems to recognize the categories in the layer. I even translate those categories into English because I noticed some problems when displaying special characters like "ó" or "ô".
I provide some pictures to show this behavior.The view from the ArcGIS for Power BI editor, displaying size and color theme.The view from the report, after clicking on "Back to Report".
Thank you in advance.
Adrián
