I have a simple map with 38 unique values (unique colors) and size of the bubbles is defined by a number. Every time I want to refresh the data all format reverts to default. Meaning, many values go to "other" label (all turn grey) and even if I take them out from the "other" all pre-set colors are gone and it just uses random allocation from color ramp.
Also the settings for the size of the bubble reverts back to default.
I have Power BI desktop Version: 2.99.782.0 64-bit (November 2021)
Does anyone have an idea how to freeze the format so it does not change back to default? Is it a bug or is there some setup feature which has to be abled/disabled?
Thanks so much in advance,
Laura
@AlessioBrusamolino - When you have a moment, could you email me directly at alatini@esri.com ? I see that we have a chat in another thread here in the forums and I would like to work with you on the issues together.
Thank you!
Thanks @Anonymous User ! It took a bit of time, but now this is not an issue any longer, thank You! 🙂
