Symbology resets when I apply a filter/slicer
9084
28
12-09-2021 12:29 AM
JannatAlasfoor
My report was working fine, but today it started being very weird. Every time I apply any filter or a slicer the colors I choose for the symbology reset.
I attached an example.
AdarshMadhavankutty
@Anonymous User
Is there an update on this - if the bug was fixed and deployed from MS .
The bug status query from esri Returns and error
Bug status:  https://support.esri.com/en/bugs/nimbus/QlVHLTAwMDE0NTI0Ng==
Adarsh
by Anonymous User
Not applicable
I cannot reproduce it... if you're seeing an issue check the version of Power BI Desktop to make sure its the latest. If you hover over the lower right corner of the map visual, you should see a version number 2022.1.98. Please confirm that.
If all the versions are the latest and you're still seeing this, please feel free to send me the pbix file with data so we can reproduce it, or work with Esri Tech support to get a new bug number.
VRamosUWH
any updates on patch deployment? still having this issue. Also tried to change points to boundaries this morning which immediately reverted back to points. about to call for a refund as advertised features DO NOT WORK
by Anonymous User
Not applicable
If you hover over the Esri logo in the lower right corner of the map, what version does it say you are using?
VRamosUWH
Hi. I'm using ArcGIS for Power BI (version 2022.1.98)
by Anonymous User
Not applicable
Interesting... would you be able to share the PBIX file with us for testing? We haven't been able to reproduce this with the fixes we put in place.
KevinRbi
Andrew -
I had a similar issue back in Fall of '21. That seems to have been resolved and my classification settings are persistent. However I have a related issue now:
When I use slicers to control the values on a heat map (i.e. - show me the heat map for all records vs. show me the heat map for just a segment), the classification does not respond. This means that the map is useless after filtering. For example - when I map the market penetration for all customer segments the natural breaks are set to adequately show the differences between the classifications. But when I filter to a particular segment, the market penetration is now only using the bottom one or two classifications.
My expectation is that the classifications would react to the slicers so that I can view the relative difference in market penetration for all or some segments in the same viz.
Is this a bug or is the functionality not supposed to be there?
AlessioBrusamolino
Hi Kevin,
did you solve your problem?
I have the same issue as you and I can't figure out if it's a bug or it's an unsupported feature. Could you let me know if you already solved it?
Thank you,
Alessio
KevinRbi
No resolution - just jumped back into forum for the first time in ~18months. I'd given up...
Any news on your end?
