Revert back to an older arcGIS Power BI version?
4989
15
09-27-2021 04:04 PM
hellomynameisjoe
Hello - ever since an update in early September 2021, ArcGIS for Power BI is not working properly: the map doesn't render at all in new maps, and in existing maps the shape files do not render properly.
Is there a way to manually revert back to an older ArcGIS version within Power BI (the round icon?)
JayMeehl
Anthony,
I am having the same Census Tract issues as discussed above. Any news on the ArcGIS for Power BI Census Tract Issue?  Will it be fixed in the next release and if so when will that be out?  I heard possible early December?  Thanks for any information.
by Anonymous User
Not applicable
Hey @JayMeehl
The update should be pushed today. If you've had Power BI open you can restart it and it should pick up the latest visual. To know for sure, hover over the Esri logo in the lower right corner and it should say Version 2021.2.95
Cheers,
Andrew
JayMeehl
Andrew,
Thanks for the update.  I see that one of the issues is fixed and I can thematically display Census Tract data however the rendering is still an issue - see attached image.  And it is also 2010 tracts, will they be updated to 2020 soon?Rendering of Census TractsRendering of Census Tracts
by Anonymous User
Not applicable
That's really odd that the geometry isn't resampling, we'll have to take a look and I can follow up on the Census Tract updates. We should have those in place.
hellomynameisjoe
Hi @Anonymous User: I'm on the latest version of ArcGIS Maps (2021.2.95) and PowerBI Version: 2.99.862.0 64-bit (November 2021).
I'm unable to render any map visuals. When I drag in Census Tracts:
1. Nothing renders (I've also tried zip codes and counties, but no luck).
2. I'm unable to change the location type (see attached image). I can change the "Represent locations as" from Points to Boundaries, but am unable to change "Locations are in".
I've uninstalled and reinstalled Power BI, but this issue persists.
Any ideas?
by Anonymous User
Not applicable
I'm unable to reproduce this, but may be following different steps. Would you be able to send a .pbix file with me so we can review it?
