Publishing a map that includes an ESRIJSON field and longitutde latitude coordinates in a report
1210
11-29-2023 12:12 PM
JepchumbaKoech
Hi, I am trying to publish a report that has an ESRIJSON file in the Location field and longitude and latitude coordinates so the map zooms to the polygons when it zooms. When I run the publishing check it fails.
Are we unable to have latitdue/longitude coordinates with a Shape field?
JepchumbaKoech
Location field( with an ESRIJSON) and longitude/latitude
NaZhang_Esri
Hi @JepchumbaKoech,
Thanks for your question! Currently, EsriJSON or XY will be accepted in order to publish/embed the report. If data is added to both Location field well and XY field wells, it will fail the check.
JepchumbaKoech
Can that be changed? Otherwise my EsriJSON doesn't zoom to each selected feature.
NaZhang_Esri
Hi @JepchumbaKoech! Actually I am a little bit confused. If you want to zoom to the Esri JSON polygons, could you try to remove the XY data since XY are not mapped? That way, it will zoom to the polygon and be able to embed/publish.
