Power BI and ArcGIS Online Integration
208
07-18-2024 12:21 PM
JonJones1
Occasional Contributor II
Hello everyone,
I'm an admin for my company's ArcGIS Online (AGOL) platform and also have experience with Power BI. I'm currently working on integrating these two platforms more effectively.
I've created several AGOL dashboards, which are great, but now my company wants to transition to using Power BI dashboards. These dashboards should include maps made in AGOL and utilize Power BI's built-in visualizations (widgets) to view and interact with the data in AGOL feature layers. I have some questions about this integration:
  1. Access to Non-Public Data: Is it possible to pull data from a hosted feature layer in AGOL that isn't shared publicly into Power BI and use it in Power BI visualizations? Also, does the type of layer (point, polygon, line) matter?
  2. Interactivity Between Maps and Visuals: If I bring in a map made in AGOL and select something in a Power BI visual, does the AGOL map filter to show that item? Conversely, is it possible to select items in the imported AGOL map and have the Power BI visualizations display data about only those features? Basically, does cross-filtering work?
  3. Publishing and Sharing Dashboards: What do the users of my Power BI dashboards need in order to interact with these dashboards? Basically, do they need AGOL viewer accounts to access it?
In my research, I found an old thread from 2018, https://community.esri.com/t5/arcgis-online-questions/using-excel-to-access-arcgis-online-automated/...  about using Power Query to access ArcGIS Online data. I'm unsure if it's still relevant because it's somewhat dated and lengthy. Is this still the best source for learning how to pull data from AGOL into Power BI?
I just wanted to ask one more time the question above because this is super important to me: Is cross-filtering possible? For example, if I zoom in on an area on the AGOL map or select features on the AGOL map that is in Power BI, can the Power BI visuals update accordingly? Also, can the opposite happen where I select items in a Power BI table visual can the imported AGOL map filters to show only those items?
FloraAdekola
New Contributor II
1. Yes, it is possible to pull data from a hosted feature layer in AGOL that isn't shared publicly into Power BI and use it in Power BI visualizations. You can add a layer from AGOL into the power bi map.
2. You can use the Join layer to connect your power bi data to your AGOL layer. This creates an interaction between your map and other Power bi Visuals. You can use a power bi slicer on your map as well.
3. Yes, they need an AGOL viewer account.
Hope this helps.
JonJones1
Thank you so much for your input!
One follow-up question: Is reading through this still considered the best way to understand how to connect your data in AGOL via Power BI?
Just wanted to make sure there isn't some "standard issue" blog posts, YouTube videos, or other resources that provide a clear, up-to-date explanation of the integration process that I'm missing?
Thank you again for responding, I was starting to think this post was dead and I was never going to get an answer, so thank you!
