Maps not loading
1269
02-14-2025 03:07 AM
Labels (3)
Storm119911
Update - now all my layers have been removed from the maps where some were working earlier and others not. I have not updated or changed anything in the report or changed setting of the layers in ArcGIS. It won't let me sign in to ArcGIS when I'm in Power BI to add the layers back in. Comes back with unexpected error. When I have a map that has layers working, there is no option to validate the map. This is frustrating as we have several published reports for the public who now cannot view several maps where all the data is.
I have a published Power BI report but some maps are showing an error saying they do not meet published requirements. The layers are set as public in ArcGIS, the map previously met validation requirements and was working the other day. No changes have been made. I have removed and put back in, same with the lat and long however keep getting the same error. When I delete the map and try to put back in I sign in but it doesn't load or do anything. Any advice why this isn't working? I am working in the Power BI service as the report is already published so don't want to remove and then have to get a new link if work in the desktop app and reupload to the service..
AlagiriVenkatachal
Hi @Storm119911
Could you please let me know if you are able to create a new visual on a report and sign in to ArcGIS from the new Map?
When you are on the Map, you need to be signed in to ArcGIS and be editing the report to see the option to Validate the map. You won't see the option to Validate the Map to embed / publish-to-web if you are a guest user.
Here are the requirements to Embed/Publish-to-web:
https://doc.arcgis.com/en/microsoft-365/latest/power-bi/publish-to-web.htm
Alagiri
Storm119911
*update* started working again out of nowhere! Seems to be fixed for now and maps showing again which is good.
If I add a new map in the Power Bi service it won't let me sign in, it just says unexpected error.
I can still sign in if I create a new visual in power bi desktop though.
