Map labels not showing when published- ArcGIS for PowerBI
901
04-12-2024 01:23 PM
YuelinJiang
Hi Community,
I built a map with ArcGIS for PowerBI in my dashboard. I am logged in with my ArcGIS pro account for the plug-in app. The local dashboard map labels look like this:
When I hit "Publish" and view my online dashboard on PowerBI server, the map labels disappear or show up inconsistently:
This bug only started to happen two days ago. Before, I had no problem publishing the embedded map as is.
Any help or suggestions are greatly appreciated!! 🙂
RubenDReyes
Did you were able to solve the issue, I have exactly the same behavior, my report was working and all of a sudden stopped.
Best regards
Rubén
cdevault_pickett
We are also experiencing this. Curious to see if you've found a solution.
