Layers lock without a match in join layer
627
11-26-2025 07:10 AM
SJ-N1
Hi, the company where i work is a merger of 2 largers companies, this means our GIS data is in 2 different layers.
I have joined both layers with my data using the "join layer" field which works fine, but i am experiencing problems with my layers locking.
It seems that if i use my slicers to filter the data, so that i only see assets that belong to layer A, then layer B will lock, and the other way around also. Is this just have the visual works? And i need to ask the GIS department to join the layers, or is there a known workaround?
Its version 2025.2.901, if thats important information 🙂
Regards
Sune
KanikaKumar
It sounds like the visual is struggling to maintain active joins across two separate sources simultaneously. The best fix would be for the GIS department to 'Merge' these two layers into a single master Feature Class. This would give us one consistent Join Field.
A second option can be instead of joining them separately in the map visual,  try 'Appending' (Unioning) the data tables in the data prep layer (Power Query/SQL) first. > If we create one unified table that contains the IDs for both Layer A and Layer B, the visual will see it as one continuous dataset, which usually stops the 'locking' behavior when slicing.
Question: Do you have other BI visuals in addition to the ArcGIS for Power BI visual?
Thanks!
