Drill Through filters applying to visual but map does not autozoom when navigating from another page through the drill through.
407
08-14-2025 11:03 AM
CaseyMarika
The drill through filters are applying to the visual but map does not autozoom when navigating from another page through the drill through. It looks like navigating to the visual from another page using a drill through does not trigger a refresh of the map visual. If I use the Refresh Visual query in the optimize pane the visual updates and auto zooms to the filtered location. I need this to happen automatically when drilling through from another page in the report. This happens in both the desktop file and the published dashboard.
Additionally, every time the map visual page is navigated to, the Join layer updated/Layer data has filter applied popup covers a large portion of the map. Is there a way to turn this notification off?
Thank you,
Casey
NaZhang_Esri
Hi @CaseyMarika,
Thank you for your question! For the drill through question, currently, the map won't be auto-zoomed when using drill through. But this is on our roadmap and ArcGIS for Power BI will support this in the future.
For this question, if you are asking about ArcGIS feature layer/Join layer, toggle off the feature information option from the format visual pane. If you are asking about Power BI data layer, toggle off the Tooltip option.
Please let us know if you have more questions! Thank you!
CaseyMarika
No, every time the page is navigated to the map has the pop up shown in the screenshot. With smaller maps the pop up covers almost the entire map. And with several filters there are multiple pop ups that need to be closed to even see the map.
