Connection with Dashboard and Arc-Gis custom-layer
1018
07-28-2023 01:28 AM
Labels (3)
EffieFiest
Hey Esri-Community,
I am still quite a novice using ArcGis and PowerBI.
I have just customized two layers with my data using ArcGis Pro, which I will now use for my PowerBI Dashboard.
Now, the question is, how do I link my PowerBI Dashboard data with the data in the layers?
Is it possible for ArcGis in PowerBI to interact with my data I use in my PowerBI Dashboard?
Best,
Effie
LeslieUK
Hi @EffieFiest
If I understand you correctly, firstly you will need to publish your data from ArcGIS Pro to ArcGIS Online/Enterprise (depending on what you have). Introduction to sharing web layers—ArcGIS Pro | Documentation
Then you would add data into the ArcGIS for Power BI widget from your Power BI dataset and then you would add a reference layer - which is your ArcGIS data that you published from Pro: Add content from ArcGIS—ArcGIS for Microsoft 365 | Documentation
Then you will need to join your layers: Join layers—ArcGIS for Microsoft 365 | Documentation
~Just trying to fix things~
EvansLion
Hi
The interaction between ArcGIS and Power BI visual only seems to work when the "join layer" widget is open for a specific layer as shown in the screenshot, otherwise it just doesn't work. Is this a known bug to the developers? Are there plan to fix it? It would change a lot if it were working correctly.
