Hi There,
I have created a layer in ArcGis which I have joined as a "join layer" in Power BI Desktop.
As you can see below, there are LGA administrative boundaries I have deliberately coloured in ArcGis for the Power BI visual.
![hpJoshGirleBennett_0-1707825518790.png hpJoshGirleBennett_0-1707825518790.png](https://community.esri.com/t5/image/serverpage/image-id/94585i826127F6C45ACECA/image-dimensions/647x505?v=v2)
When using the slicer to select an LGA area, the deliberately coloured outline of select LGA boundaries remains (which is what I want) however the greyed out areas disappear.
But when selecting these coloured areas, I want all the other grey outlines to appear as well as the other coloured areas if this makes sense?
There are a couple of examples below:
![hpJoshGirleBennett_1-1707825615701.png hpJoshGirleBennett_1-1707825615701.png](https://community.esri.com/t5/image/serverpage/image-id/94586iC6D50C5A6C4093DA/image-dimensions/627x497?v=v2)
![hpJoshGirleBennett_2-1707825806002.png hpJoshGirleBennett_2-1707825806002.png](https://community.esri.com/t5/image/serverpage/image-id/94587i7A879EBEE6A46131/image-dimensions/611x480?v=v2)
It looks weird if only one area is outlined on a blank map!
Would anyone be able to suggest how I can fix or workaround this either in ArcGis, Power BI or both platforms please?
Thank you!
