argis /esri maps too slow
1446
08-31-2017 09:06 PM
charmaineRodericks
Hi, I have placed Esri maps in my Demographics dahsboard with Power Bi. ( July 17 version)
Data(Sql Server 2016 -tablular) - is on premisis by acces to all users is via the Powerbi service.
Thare are arund 1120 points/records tp plot with  lat and long.
Inital load is too long , i have a filter to select area which works fine on desktop  but just too much lag time when there is multiple selection on desktop and service.
sometime it takes upto 6 mins to render and load values and data points on the Map.
I have tried different browsers , but still seem to have an issue. I have a demo on soon and if this lag time appears, i will not be use Esri maps.
Request yours assistance if there is a fix for this issue.
Kind Regards
Charmaine Rodericks
Australia
MicahBabinski
Hiya Charmaine,
Sounds like it could be your network connection, contention, and/or network latency. Is there a GIS/IT admin or manager to whom you can report this issue?
In general, drawing over 1000 features in one web map extent is know to cause performance problems. Also, a ton of other users accessing the same service (or others) can lead to a lot of network contention.
Good luck,
Micah
MikeHoney
Are you only using lat & lon or have you populated the Location field well also? Please post a snapshot of your Visualizations / Fields pane.
