ArcMap Auto Zoom Broken when Filtering by Project Selection in a Table or Filter
2139
07-08-2024 07:38 AM
JA92765
Before the update we had a map of projects which could be filtered by selecting a project name in a table. When selected the map would auto zoom in to the selected project on the map. Since the update however this appears to have broken. When a project is selected the base map zooms out to its maximum extent. Is anyone else having this issue?
I have recreated the maps from scratch and it is still happening. Projects are mapped by lat and long.
When a project is deselected the map returns to the view with all data points.
AlagiriVenkatachal
Hi @JA92765 ,
Could you please let me know if you are using ArcGIS Online or ArcGIS Enterprise and if you are signed into the platform?
Is this a custom basemap that you have on the Esri Map visual? If so, what is the coordinate system of the basemap?
I have tried your workflow with an Esri visual that uses Lat and Long for the Power BI data on a Web Mercator map and a Table visual to use to filter the Esri visual. When selecting a single record from the table, the Map zooms to the location as expected and when un-selecting the selection, the Map returns to show all the datapoints on the Map.
Could you please try your steps using a Web Mercator map or with a standard table from the Vizualization pallette to see if we can narrow down the issue?
JA92765
Could you please let me know if you are using ArcGIS Online or ArcGIS Enterprise and if you are signed into the platform? ArcGIS Online and I am signed in.
Is this a custom basemap that you have on the Esri Map visual? If so, what is the coordinate system of the basemap? I have not added a custom basemap I have been using the default basemaps available. Unless the organisation loads those on? In which case I have no control over the basemaps. its this one I believe - https://cornwallcouncil.maps.arcgis.com/home/item.html?id=927ff05a8ae447bcbd46fe4f36b38e06
Normal table has the same issue.
Thanks
LydiaStekkinger
A colleague of mine is experiencing the same issue. Using data from ArcGIS Enterprise, joined to Power BI table.
Jbrand
I am experiencing this issue too. Has a workaround been identified? Is this a known defect?
RobertHartgerink
Users in my organisation are experiencing the same issue. The ArcGIS for Power BI map visual seems to work  when using the auto zoom function in the Power BI Desktop. However, when the report has been published to the Power BI-service it feels like the 'Lock extent' option is turned on and the map no longer auto zooms in and out when filtering data.
