ArcGIS Power BI Tooltips
1054
08-07-2024 08:38 AM
JaredFaurschou
I have created a visual with the ArcGIS Maps for Power BI, and have added data under the tooltips for pop-ups when hovering over data points on the map. My questions is, I would like the formatting for these to be corrected. The Estimated Invoice, I've tried changing the formatting to currency, but still does not reflect, and the start date is not reflecting correctly (01/012024). All other data sets are working correctly. See image below:
RodPBI
You should be able to use the Power BI format feature for the fields or measures you drop into the tooltip well - but alas, I get the same issue you do (no formatting).  A way that will work is to create and specify a Report Page for the ArcGIS visual Tooltip.
NaZhang_Esri
Hi @JaredFaurschou and @RodPBI,
Thanks for the question and reply. We have fixed this issue and you should be able to see the updates in the future release.
Thanks for your patience.
