Ability to de-select by clicking on currently selected item
517
04-21-2025 02:53 PM
Status: Implemented
LiamCurrie
There are only 2 ways to de-select: 1. click on a blank area of the map, 2. go to the menu > selection tool > clear selection.
(1) works if you are not zoomed in on your map with adjacent boundaries, but if you are then you cannot use this option. (2) technically works but is very inconvenient and not intuitive to users.
There should be another way to de-select without going into the menu. Usually this is done by letting users click on the selected item and this causing the application to clear selection.
5 Comments
YannickM
Yes please!
NaZhang_Esri
Thank you @LiamCurrie and @YannickM for your feedback! I have logged this issue for us to investigate.
NaZhang_Esri
NaZhang_Esri
Status changed to: Closed
@LiamCurrie @YannickM - This has been implemented for the ArcGIS for Power BI version 2025.2 and after.
NaZhang_Esri
