Triggers Unavailable Under ArcGIS Enterprise Connector
769
11-02-2023 06:36 AM
Clayton-Cooley
Recently upgraded to Enterprise 11.1 and I'm trying to test out the Power Automate Connector for ArcGIS Enterprise. Unfortunately, there are no triggers available when I view the connector. Anyone else having this issue? I know it was recently released, so there may still be some things they're ironing out.
SeanKMcGinnis
Good Day @Clayton-Cooley  - currently there are no triggers for ArcGIS Enterprise, but here is a blog post on you can enable webhooks and begin using the Connector. We are looking to deploy triggers in the Enterprise connector in conjunction with the ArcGIS Enterprise 11.2 release.
-sean
Sean McGinnis - ArcGIS for Microsoft 365 Product Manager
LeviCecil
Hello, I'm trying to use the Enterprise triggers recreate a flow I have in AGOL. The problem is happening at the first for each loop. "Body" is not a selectable parameter in the When A Record Is Created In A Feature Layer Enterprise trigger. I tried grabbing "body" from the dynamic content tab instead but it prints to the code console as "triggerBody()" and the flow fails. This is not an issue with the AGOL version of this trigger. Is this missing functionality? We're at Enterprise 11.1 but we'll be upgrading to 11.3 in the coming weeks.
Clayton-Cooley
Thank you @SeanKMcGinnis! I followed the instructions in that blog post but I'm getting an error when trying to select a feature layer. I reached out to the person who published it, so hopefully than can help me out.
